Home > Help Needed / General Tech Chat > Fitting turbo engine? Put it on subframe first? or drop in after?
hammoj28turbo
Member #: 1502
Aberdeenshire, scotland.
Just wanted to ask a quick question. Basically when it comes to sticking the running gear/engine back onto the car should i:
Put the turbo engine on the subframe and then lift the shell up and drop over so that the engine goes in with the subby. then bolt on the exhaust manifold, carb etc after.
OR
should i put the subframe on seperately then build up the engine with the manifold on and drop it in?
Any advice here would be much appreciated.
Thanks
James.
Either or, makes little difference.
Badger
Member #: 1488
I'd personally say depends on your facilities. If you havn't got an engine crane, or are using a flip front, drop the car onto it. If not vice versa.
There is no sense crying over every mistake- you just keep on trying til you run out of cake.
Nick
Member #: 154
Midlands
i hate doing the car lifting method, prefer to drop the engine in from the top even if i had to hire a crane for a day.
hammoj28turbo
Member #: 1502
Cheers guys, i was worried that i might have trouble bolting on all the turbo bits once the engine was in situe. Think i might just lift the car and slide the gnien in along with the subframe.
Thanks very much.
nogin
Member #: 487
westbury, wiltshire
i think you have trouble no matter what way you do it, or at least i find it annoying and hard sometimes
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
hammoj28turbo
Member #: 1502
Ahh, thought that might be the answer.lol.
Nick
Member #: 154
Midlands
the only bit i ever had trouble with ont eh std T3 setup was getting that fucking downpipe to seal properly even after i modded my clamp.
i have been doing these since the stone age
and my prefrence is... subby first and then the engine etc
you can see where you are heading if you look at it in phases
toms right as well though
its just My prefrence!
Badger
Member #: 1488
Tend to agree with you on that one mate, but needs must as the devil drives (or lack of money in my case!)
I've never really understood why anyone would want to remove the whole subframe when only the engine needs to come out.
It's so much extra work, not least having to bleed the brakes..
Even with a full steel front end on, me and my bro can easy lift an engine straight in (and we're skinny buggers).
Ben H
Member #: 184
Melton Mowbray, Pie Country
Yep I have to agree with Wil. I have removed a subframe and engine as one once, never again. You have to get the body so high to clear the engine and balancing the subframe is a pain.
http://www.twin-turbo.co.uk
To be honest I am going to drop the engine in after the subframe when It comes to reassembly.
It was a bit of a fiddle to lift the shell off the the engine and when I have a fresh painted shell I don't want to risk dropping it.
[IMG]
And if you do it like above, you now have a car you can't move easily, and an engine top heavy on a subframe with wheels that want to go anywhere but straight!
colas
Member #: 102
Pennsylvania USA
I always do the engine in from the top. I hate bleeding brakes.
