Home > General Chat > 2005 MG TF 160
Me and the old man are thinking of getting one of these for my mum tomorrow, its done 8k, at right money and its got all the optional extras.
Its a minter right now, but what sort of things are these things prone to?
Any input welcome
Joe
stefaz
Member #: 1656
stoke-on-trent
AFAIK they rust around the intake on the rear quarters. other than that i think as long as the roof is sound - ie no mould and all is smooth go for it mate
mikemph
Member #: 449
Oxford
HEAD GASKETs, although MG have tried to solve the problem with steel head dowels they head gasket still go. I had one for a year from new, most fo the driving it did was motorway mileage. The gasket went about 2 days before I traded it in.
I seriously recomend you check which tyres have been fitted, the goodyear GSD2 are the ones you want, the GSD3 really bugger up the handling. If the GSD3 have been fitted you will more than likely want to change the tyres if feels so bad like it wants to swap end all the time.
Sumfin special
Member #: 677
Buckinghamshire
Yeah i also heard that if you buy one be prepared to replace the head gasket apparently a common problem.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Headgasket is the result of any cooling problem....
Its not that they just blow a gasket!
alex
AlexF
Badger
Member #: 1488
Dunno how much use this is, but this is what wiki has got to say about it:
"The F is well-known for its poorly designed original head gasket and head gasket failure is a common cause of breakdown[citation needed]. Although the early (pre 2000) MG Fs had Nylon dowels for locating the head to the block, these were updated in 2000 to metal. This stopped one cause of head gasket failure when the head would move very slightly against the gasket.
In the 2005 model year updates, MG Rover added a low coolant sensor to the MG TF, which should virtually eradicate the problem from the car when coolant loss is at fault as the driver will be warned prior to any serious damage occurring. Destined to be introduced with the EUIV emissions compliant engine in late 2005 was a revised triple layer gasket and strengthened oil rail. The aim of the latter is to improve engine rigidity. But this was never introduced on the MG TF made by MG Rover Group as the company failed before it was introduced.
In the MG TF which will be launched by Nanjing Automotive in 2007, the 'N' series engine (basically the aforementioned EUIV compliant K Series) will have these modifications as standard."
Edited by Badger on 14th Jun, 2007.
There is no sense crying over every mistake- you just keep on trying til you run out of cake.
Water pipes that run front to back rot out I believe, shouldn't be a problem on a 2 year old car but then with good old Rover group you never know.....
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Rust came standard on most Rovers, I think it even had a part number.
On 7th Nov, 2008 Nic said:
naeJ
m
Ben H
Member #: 184
Melton Mowbray, Pie Country
One day I would like a thred that mentions the K series engine and someone doesn't mention the head gasket only to be countered by they are fine. It is not as if they are even that difficult or expensive to change.
All I can say regarding the TF is that you get what you pay for. Not as good as an MX-5 (IMO) but a reasonable 2 seater drop top.
http://www.twin-turbo.co.uk
mikemph
Member #: 449
Oxford
The 160 version is slightly trickier to do as there is the VVC to contend with.
I had one and was pretty happy with it. I can't fault is apart from head gasket going. I never had to pay for it as it was warranty work.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
They sure do Tom!
And when they go they tend to either drop all the coolant in seconds and cook the engine or they leak a tiny amount which stops the system holding pressure giving the symptoms of HGF (the term every Rover K engine'd owner will have heard LOL).
I know a fair amount about these engine - I've done loads of work on them.
The one I did was a right nightmare - the coolant pipes underneath were at fault but they looked fine and dry. In the end did the HG and I wasn't happy that it looked like it had failed at all!
The engine is very sensitive to cooling - its marginal I guess. Soon as the level drops or the rad looses a few pipes/fins the problems start. Thrashing them from cold doesn't help either!
Alex
AlexF
mikemph
Member #: 449
Oxford
One mod that does help the problem is using the elise remote thermostat housing. Less thermal shock to the engine, not really sure on the workings but does work well aparently.
HGF is far more common on rear engine k series cars which does tend to indicate the coolant pipes and thermal shock arguement.
I have had everything from Metro GTi, rover 214,216, MGZR 160, MGTF 160. The only one I had a problem with is the MGTF.
Although I did have the head off all off the metro when it was ported.
I have worked on just about every k series you could think of from 1.1 - 1.8 and the only problems that they ever seem to have is HGF. Most of them were plastic dowel types. Nearly all of them seem to go between the oil and water ways.
The only one that bust out the side of the block was my MGTF.
I would still buy another at the right price and condition, nice run about car.
