Home > Help Needed / General Tech Chat > Embarrased to ask but.....................?
1380turbo
Member #: 1211
Working up the BHP ladder.
OK OK i'd rather ask than destroy years of work so here goes.
The Turbo engine ive built up was converted from N/A...so...i am no totally sure where all the pipes goto? *blush*
Turbo to intercooler to Carb is all obvious but where does the pipe from the actuator on the T3 go?
And the dumpvalve.....where does the smaller tube goto?
Any links to block diagrams or phots's would be helpful.
All abuse and sarcasm welcome *tongue*
Thanks
Karl
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
faq :)
AlexF
Nick
Member #: 154
Midlands
pipe from the actuator goes to the compressor housing, there's a T piece on it, block the other side off if you're not using the ECU/boost solenoid.
the dump valve trigger goes onto the inlet manifold.
1380turbo
Member #: 1211
Bud666 thats great! Thanks
