| Home > Help Needed / General Tech Chat > Metro 4 Pot Brakes under 10s?? | |||||||
17th Jun, 2007 at 08:59:09pm
Will 4 pots fit under Force Race Wheels??? With or without mods? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
17th Jun, 2007 at 09:26:10pm
NO! On 13th Jul, 2012 Ben H said:
197 Posts Member #: 1488 Advanced Member Bristol |
17th Jun, 2007 at 09:38:35pm
Effectively,. no. This is a bit of an old one now, but here's the run down:
There is no sense crying over every mistake- you just keep on trying til you run out of cake. |
17th Jun, 2007 at 09:46:06pm
Rightho point taken! Did a search but couldnt find much. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
18th Jun, 2007 at 11:10:52am
On 17th of Jun, 2007 at 09:38pm Badger said:
Effectively,. no. This is a bit of an old one now, but here's the run down: As standard they will not fit under anything less than 12s. Some people have managed to turn down the discs and modify the calipers to fit under tens but the general consensus is that this is a bit dangerous. Dangerous in the wrong hands yes but what do you think the Miglia boys used pre alloy calipers! 4 pots can be made to successfully fit under any 10 inch wheel safely. Turbo Dave will be able to tell you if the Fiesta route will give as good brakes as S discs/4pots as this is the other cheap option. From memory I think the Fiesta brakes on paper were not as good as S discs? On 5th Sep, 2011 Vegard said:
18th Jun, 2007 at 12:02:03pm
I have a cooper S Setup, but i like the look of the 4 Pots from the Metro but i do prefer the Alloy ones, think i might sell my Cooper S Setup and Buy an Alloy Set. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
524 Posts Member #: 1380 Post Whore Swindon |
18th Jun, 2007 at 12:50:38pm
i'm going fiesta route. although i seem to see people say that they're not as good.
neil_g, with all due respect, your the worse salesman on TM since rob_h tried to sell his own ass |
18th Jun, 2007 at 01:27:50pm
My S ones were pretty good. The Fiesta ones look crap, i cant see how a 1 pot brake can be better than 2 but im no expert. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
18th Jun, 2007 at 03:44:22pm
1 pot sliding and 2 pot fixed should be the same (roughly but I guess in this cas the Siesta caliper is alloy and pad may be bigger), 2 pot sliding is a different story though. Edited by Jay#2 on 18th Jun, 2007. On 7th Nov, 2008 Nic said:
18th Jun, 2007 at 05:10:20pm
got F-Brakes on mine with 7.9 discs to fit under 10's and it stops very well. never driven on an S setup. I'm using a .70 MC I might go upto a .75 to see how that effects things. I run a supercharger and I don't care the TB is on the wrong side.
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
18th Jun, 2007 at 06:20:50pm
i have used fezzy ones which i found were way better than S ones, and i have a set of 4 pots running 10" wheels which are fine too
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
18th Jun, 2007 at 06:28:58pm
hi, right then any body want an 's' setup??plus i have some cooper 7"s....lol
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
18th Jun, 2007 at 06:54:18pm
I know someone who is after a set of S brakes.
In the 13's at last!.. Just |
18th Jun, 2007 at 08:05:02pm
On 18th of Jun, 2007 at 12:50pm Ollie said:
but, i find its people that don't have them saying they're not as good and people that use them say they're fine :S I've been running them for a while now and they are about the same as 8.4" brakes, they may be marginally better or worse but I can't tell. Isambard Kingdom Brunel said:
18th Jun, 2007 at 10:31:35pm
I think mine stops as well as the lads at my local club that rum 8.4's I would say about the same....
