Home > Help Needed / General Tech Chat > Hi-Lift rockers
davvy1uk
Member #: 330
Aberdeenshire
Hi
Can anyone tell me if hi-lift (Non Roller) rockers are a worthwhile addition to a fairly standard A series Turbo please. I just happen to have a good set lying about from a previous project and was wondering if they were any use on the turbo engine.
Dave
I was very kindly given a set of Pressed Steel ones by Sir Benross the other day and apperently these are commonly used amongst us Turbo Chaps. These seem to be a good choice as they are 1.3.
i use 1.5 rollers, although the advantage you'll see by just fitting those i'd guess is fairly small. not something i've done though. Mine are part of the overall package.
i'd save them for when you rebuild it so they're not worn out!
*smiley*
davvy1uk
Member #: 330
Aberdeenshire
Cheers Iain
It has only recently been rebuilt but with standard A+ rockers. I was just wondering if they were any advantage since I had a set anyway.
Dave
