Home > Help Needed / General Tech Chat > boost adjuster
nobbie
Member #: 162
hi guys i am in the final stages of finishing my car, i just wanted to meak sure i have conected the boost adjuster up corectly, i have put it in place of the ecu, or at least were i think the ecu goes. when i got the turbo unit there was a pipe from the turbo that was just loose and not conected to anything so i thought that this is were the ecu went, so i got rid of that and put my boost adjuster in its place.
jamesfawcett
Member #: 218
Bingley, West Yorkshire
yeah should be, does it come from the T piece yeah? Does the other pipe at the end of that one, also joining to the same copper T piece, go loop up and arround to the turbo?
nobbie
Member #: 162
yea there is a t piece, the other end goes to the actuator.
jamesfawcett
Member #: 218
yeah according ot the FAQ i think htats perfect then
fireman-sam
Member #: 301
if you put a bleed valve on that pipe it will work fine and that pipe went to a brass valve with two wires that was controled by the ecu
