| Home > Help Needed / General Tech Chat > Its Bad ... very bad - HELP ***UPDATE *** | |||||||
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
6th Jun, 2004 at 07:48:07pm
Run the car again today .. Edited by b12 on 7th Jun, 2004. TurboLessTosser |
6th Jun, 2004 at 10:43:12pm
Stop driving it about while its not running properly...
AlexF |
7th Jun, 2004 at 12:00:37am
I got this also, im hoping that from changing all the gaskets it will be ok again. The oil level in the dashpot didnt go down though so it shouldnt be that. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
7th Jun, 2004 at 08:59:25am
Smoke from the carb... White or grey smoke? If white, it's likely the o-ring on the float bowl 'lid' is leaking fuel out... Chances are the lid is warped aswell - a common problem.
7th Jun, 2004 at 09:02:20am
oh, regarding the lid - i usually just file off the two little 'lugs' sticking up, then 'draw' the lid over a large file to take off the high bits (usually around the bolt holes). Don't get it perfectly flat, just flatter! The new (soft) seal will stop the leaks! On 17th Nov, 2014 Tom Fenton said:
7th Jun, 2004 at 09:40:27am
TurboDave
7th Jun, 2004 at 09:58:15am
Smoke on idle, most likely turbo, possible valve stem seals.
7th Jun, 2004 at 10:06:29am
Iain... he's not talking about the smoke out the exh.,...
AlexF |
7th Jun, 2004 at 10:15:33am
thought that was a second problem of his?
7th Jun, 2004 at 10:47:13am
doh!
AlexF |
7th Jun, 2004 at 11:08:58am
hello ... yes it is STEVE ,..
TurboLessTosser |
7th Jun, 2004 at 11:19:57am
little bit of smoke on idle isnt the end of the world, just budget for a turbo rebuild in the future, may last a long time like it, depends just how bad it is.
7th Jun, 2004 at 12:03:24pm
Things to buy for the carb:
7th Jun, 2004 at 06:23:25pm
Im going to order that lot, just incase i get the same problem still when i startup, i remember mine was white smoke, and looked like it came from the very bottom of the carb.
7th Jun, 2004 at 10:01:35pm
JIM .... you can do it ... the welding I mean ; Just be ultra clean, patient and do a small bit at a time !
7th Jun, 2004 at 10:33:18pm
TurboLessTosser |
8th Jun, 2004 at 10:48:55am
blue smoke after 30s idle is as ive said before mate. black smoke is rich running.
8th Jun, 2004 at 11:14:24am
cheers iain matey !!
TurboLessTosser |
8th Jun, 2004 at 11:17:53am
could be valve stem seals...
8th Jun, 2004 at 11:57:01am
too much oil pressurew aswell - 55 is more than enough, but no less than 25 at tickover when piping hot! On 17th Nov, 2014 Tom Fenton said:
8th Jun, 2004 at 12:30:57pm
Blue smoke can be engine as well as turbo related as Iain has said!
AlexF |
8th Jun, 2004 at 12:53:46pm
mines going for rolling road as soon as its back on the road, if not a week after. I think it cost 80 quid ot have my standard 1.3 setup, i think if it was twin carbs it costs 120, not sure about how much they will rob u for a turbo! Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
8th Jun, 2004 at 01:10:07pm
Take it to Baldwins. He will do it PROPERLY, and he gets you involved in the driving and tweaking aswell... On 17th Nov, 2014 Tom Fenton said:
![]() 1128 Posts Member #: 142 Post Whore Winchester |
8th Jun, 2004 at 01:18:28pm
when my old engine went, one of the things that went were the stem seals, it used to chuck out huge clouds of smoke on start up
8th Jun, 2004 at 01:37:42pm
I think it was 15/40 i put in ,,,, whatever it said in the Metro Haynes Manual !!
TurboLessTosser |
