Home > Wanted > boost solenoids wanted.
Nick
Member #: 154
Midlands
anyone got any spare metro boost solenoids? after 2 if possible.
also after a cherry bomb backbox with the round tailpipe rather than the oval.
Nick :)
Nick, worth looking to see if a NJ75 would do the job. much better valve *smiley*
Search ebay for an "amal" valve, this has 3 ports, two are common, the third opens when you power the valve.
Nick
Member #: 154
Midlands
pretty sure i've got an amal valve in the garage actually from keans cossie cooler, will have a play with that cheers tom.
got the solenoid switched from the jolt at the minute to raise the boost after 4k similar to the std metro setup, but with more boost, and 2 bleed valves lol.
What you can do with the amal valve is pipe the common one to a bleed valve. This valve can be set to give you low boost.
Then the other port to another bleed valve, fo high boost.
And if you put a solenoid valve in line to the amal valve you could have three boost levels if that is what you are trying to achieve? Low boost = actuator, Med boost actuator + 1 bleed v/v, High boost actuator + 1 bleed valve + open amal valve.
The Cossie valves have a restrictor in one leg that you might find you need to drill out.
no need to drill, wind in a self tapper and give it a heave
Bet you say that to all the girls eh nic??! :)
i wish
