Home > Help Needed / General Tech Chat > mpi tank
jamesfawcett
Member #: 218
Bingley, West Yorkshire
found me a mpi tank with pump, 50 quid
are the outlets and inlets all the right sizE? Im gonna buy it if it means not having to worry about T pieces or modding mine!
in and out are 8mm...
Just do the trick with adding the restrictor at the inlet to the regulator and you won't have a problem...
