Home > For Sale > complete stage 3 1330 turbo + many parts for conversion
mini_jim
Member #: 1702
kent
right i have decided to go a completly different direction now so have the following up for sale.
a complete 1330cc stage 3 turbo engine with t3 turbo
hasnt even been fully bedded in yet so the engine is mint as are the parts..
refurbed turbo, no play what so ever,
carb rebuilt with kit,
stage 3 morspeed head, with larger chambers to lower compression ratio,
new valves and double valve springs,
minispeed forged highlift rockers, 1-5-1
gen turbo block, decked, chem cleaned and machined +060 to 1330cc new core plugs fitted and painted red,
brand new silicon oil feed pipe,
brand new braided steel oil feed pipe,
avonbar phase 2 cam,
bleed valve fitted. set at 10psi,
dump valve fitted and pipe machened into inlet manifold,
brand new pistons sent to v-maxx and machned out by a further 10cc each so they have a 15cc dish,
brand new rings,
brand new high output avonbar oil and water pumps,
FULLY rebult box new bearings and part,
4pin cross diff,
all new gaskets and oil seals on whole of engine,
crank reground, with new mains bearings,
infact all bearings are brand new,
block and head mached for 11 studs,
reconed electric dizzy and brand new leads,
duplex timing chain,
brand new oil cooler,
compition head gasket,
brand new alternator,
centre mains strap fitted.
comes with all ancilliries + turbo down pipe, dump valve, boost adjuster, 4 core rad, intercooler, new bulk head box, mpi tank + new braided pipe for return line, new minispeed fuel pressure regulator + more
litteraly a whole conversion ready to go in to your car.
looking for around £1,200 for the whole lot but offers will be considerd.
many thanks.
jim..
0 -- CASUALTY IN 5 SECONDS
mattyking
Member #: 873
Thatcham, berkshire
that isnt a picture of your engine bay is it. because a guy on other forum a swear sold his engine kit the same set up as you stated.??
What make are the pistons?
