| Home > Help Needed / General Tech Chat > help subframe pain | |||||||
![]() 82 Posts Member #: 78 Advanced Member milton keynes |
7th Jun, 2004 at 08:42:32pm
my rear subframe has become a real pain!!!! |
8th Jun, 2004 at 11:09:18am
sill/healboard off and new metal/nuts i think |
8th Jun, 2004 at 11:58:05am
had to cut open my sills and get to them from there! Then weld up the little squares in my sills agai nand paint over! Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
8th Jun, 2004 at 02:19:09pm
tell me about it ian i have just painted it. i have managed to do it though i cut a small hole in the bin there was just enough room to get a spanner in to hold a nut on the back or the screw. just got to add all the other bits now i carnt wait to get back out in it |
8th Jun, 2004 at 02:27:44pm
you can get to those by cutting in the rear bin, got the t-shirt etc! On 21st Jan, 2011 fastcarl said:
166 Posts Member #: 221 Advanced Member |
9th Jun, 2004 at 11:26:14am
Last time this happen to me, I just whacked the outer sills off........they needed replaced anyhow!
4 Posts Member #: 311 Junior Member |
22nd Jun, 2004 at 02:24:18pm
I had to replace my rear sub last year, and chose to cut open the inside, like others have said, there?s just enough room! Then just do your best to tidy the gapping holes back up! |
461 Posts Member #: 91 Senior Member Live @ Worksop, Work @ Rotherham |
22nd Jun, 2004 at 11:20:42pm
Get yourself an imperial thread repair kit from http://www.namrick.co.uk/browse.asp?PCID=28 works a treat and very easy. |
24th Jun, 2004 at 06:02:35pm
get circular hole saw then put rubber bung in the hole Crystal Sound Audio said:
not the best news. You could just remove enough so you can get at the back i guess.
