Home > Help Needed / General Tech Chat > 1275 non turbo 998 non turbo
Zeemax Power
Member #: 393
Oulton Park
making an engine out of parts off both and i'm a bit stuck the 998 is the block i'm using.
Its old engine and out of a metro. I cant get the dizzy out of my 1275 with the module on the side to fit in. Whats the best way to combat this? Do i need to keep to the same dizzy or is there anyway of using it by changing something?
Any problems about using a 1275 carb on a 998 ?
http://www.Zeemax.com
I tried to fit a 1275 dizzy into a 998 block, I made an adapter up and it did run but could never get the thing to run right. Ended up using the standard A dizzy in the end from the 998.
Zeemax Power
Member #: 393
Oulton Park
thanks for that matty wont waste time on it
