| Home > General Chat > COME ON YOU LOT! ignition advance??????? | |||||||
7th Jun, 2004 at 09:52:48pm
So people what is your dizzy set to as i've just pulled mine out and just wondered how much more i could retard things. Edited by Miniwilliams on 8th Jun, 2004. Best 1/4 mile 13.2 seconds @116 mph
9th Jun, 2004 at 09:32:58am
mine is set to about 8 at idel rising to 16 by 3000 rpm
AlexF |
9th Jun, 2004 at 09:36:18am
My Maximum is 58 Degrees On 15th May, 2009 TurboDave said:
9th Jun, 2004 at 10:02:42am
Mines still standard metro set, but i couldnt tell you! Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
9th Jun, 2004 at 12:13:53pm
I'm sure Ive posted this ten times:
9th Jun, 2004 at 12:41:27pm
eleven... On 17th Nov, 2014 Tom Fenton said:
263 Posts Member #: 115 Senior Member Austria, near Vienna |
9th Jun, 2004 at 04:10:01pm
Dave, eleven ? at 1500rpm with vacuum hose to dizzy disconnected? Bimmer Twinky headed and turboed A-Series:
![]() 2641 Posts Member #: 19 Post Whore newcastle |
9th Jun, 2004 at 04:20:47pm
8 Everyone knows that instructions only have to be read if the thing doesn't work....
421 Posts Member #: 245 Senior Member |
9th Jun, 2004 at 04:22:41pm
14 |
9th Jun, 2004 at 04:24:22pm
although mine is 58, I have boost retard, so it brings it down a bit On 15th May, 2009 TurboDave said:
9th Jun, 2004 at 05:04:53pm
No - i meant Will has posted his advance figure Eleven times.
9th Jun, 2004 at 05:09:34pm
in that case, mine is banana's On 15th May, 2009 TurboDave said:
9th Jun, 2004 at 05:14:10pm
So there you go Matt, pick a number between 8 and 58!..
9th Jun, 2004 at 07:14:21pm
Hell!! yes i wasn't expecting such a big difference LOL, thought if they were all simular then i'd have an idea! thanks any way chaps.
9th Jun, 2004 at 10:04:22pm
what do you currently run matt?
AlexF |
29th Jul, 2005 at 06:11:19pm
Back to this.. I need to setup my ignition properly. Mark: What should the timing be? On 13th Jul, 2012 Ben H said:
![]() 725 Posts Member #: 177 Avon Park 2006 Class D Winner Woburn Sands |
29th Jul, 2005 at 06:20:28pm
mine is 50 degrees advance @ 3000 rpm 16V project underway |
29th Jul, 2005 at 08:36:08pm
28 degrees on the std dissy works to about 10 psi.
AlexF |
![]() 65 Posts Member #: 613 Class D Massive Regular glasgow |
29th Jul, 2005 at 09:02:14pm
vaguely remember something dave vizard said along the lines of you want to run 36 degrees advance all in by 3000rpm.To get this you open up your dizzy and the base plate has a number on it,which is the amount of mechanical advance the dizzy has.Take this number and add to it the psi you run on full boost (i.e. if you run 15 psi and your dizzy base plate says 10 then that's 25) and then subtract this no. from 36 to get the amount of advance to dial in ,in this case 11 degrees (36-25=11)
1st Aug, 2005 at 10:46:51am
hell this is an oldy:)
