| Home > Help Needed / General Tech Chat > Bimmer twinky heads the same? | |||||||
![]() 140 Posts Member #: 1367 Advanced Member Cape Town, South Africa |
4th Jul, 2007 at 12:21:15am
Hi, just a quick question.
123 Posts Member #: 1234 Advanced Member Chester |
5th Jul, 2007 at 09:22:42pm
I am no expert, but I believe the casting is the same. The valves are the same size, but they have thinner (5mm) valve stems. The oil feed to the cams is in a different place as is the water temperature sender. The RS cams have higher lift and longer duration and have 38mm throttle bodies.
5th Jul, 2007 at 09:30:53pm
The front plate mounts are different, but easilly altered.
1425 Posts Member #: 690 Post Whore Norfolk |
5th Jul, 2007 at 10:01:34pm
The only real difference is the oil feed to the head - the K12's have it through the front gallery between the cams - not up the head like the A series and k100/k1100 heads - this means either boring up into the head to generate a feed through the block or external feed through the drilling at the rear of the head -easiest option(this is there on K100/k1100 heads as well)
If Carling made Mini engines
