Home > Help Needed / General Tech Chat > K series head - where do you put the thermostat?
udo
Member #: 1799
Lincoln
As above really folks the K head has no thermostat mounting like the A series so how / where do people mount them?
Pictures when be great if possible
Ian
The most common method ive seen is using 2 A series thermostat housings back to back with the thermostat sandwiched in between. Its located in the same position as the A series in relation to the head and rad.
danboy
Member #: 1381
Here's a bit of reading for you to do!
http://web.tiscali.it/elise_s1/
This info could also be of benifit to any turbo / electric water pump installation. (See section on Iron block engines)
I like the idea of the two thermostat housings as a simple and cheap solution if it works OK.
Regards
Dave
Edited by danboy on 6th Jul, 2007.
you can get stats that slide into a rad hose.
Good point...would look a hell of alot neater!
udo
Member #: 1799
Lincoln
Any ideas where from?
Prefer that idea to the back to back housings - much neater
Also while I'm on the subject where do people take the heater take off from?
thanks
only seen them on vintage tractors! lol!
it was only a normal looking stat that was the right sized od to go in the pipe. should be easy enough
danboy
Member #: 1381
Some older Fiats used an external Thermostat. Might be worth a look.
Regards
Dave
johnK
Member #: 690
Norfolk
You can pick up "external" thermostats from various kit car suppliers - which can be made to work well and have bypass systems in them
JK
If Carling made Mini engines
John, what thermostat are using, and where have you got it mounted?
I don't bother with a thermostat
johnK
Member #: 690
Norfolk
I don't run one on the gold car - but that has leccie pump!
- for using std water pumps - the thermostat goes into the "top hose" between head and rad, the thermostat I use is one from NF Auto's (I think) - with a bypass to allow water circulation in the head block - whilst the stat is closed - the bypass feeds into the hose which goes from the bottom of the rad back into the pump. Also the top outlet from the head has a feed to the heater.
no overheating problems on a side mounted rad - and gives nice control of water temps
hope this helps
JK
udo
Member #: 1799
Lincoln
Cheers all just need to do a search
