| Home > Technical Chat > Dyno a Miniengine | |||||||
![]() 520 Posts Member #: 189 Post Whore Norway |
12th Jul, 2007 at 09:40:59pm
I was wondering about running in my new engine, when it is finnished that is :) I was thinking about doing this outside the car, on a dyno bench, but that is not very practacal to do with a min gearbox. Can I use a sump from a Midget?? Will that sump fit my 1275 S-engine?? What else do I need?? www.shag.no |
12th Jul, 2007 at 10:13:28pm
could the engine not just be mounted to an empty mini gearbox casing, flywheel fitted as per normal. Then some sort of drive taken from the flywheel itself?
Edited by SumpNut on 12th Jul, 2007. |
12th Jul, 2007 at 10:24:46pm
That would be a great way to do it. That way I dont have to buy a new Midget sump :) www.shag.no |
19th Jul, 2007 at 11:47:11am
If you were local I'd let you borrow my dyno gearbox :)
AlexF |
19th Jul, 2007 at 01:59:18pm
some dyno's you can use your proper box. since the engine is connected to the dyno via the crank ( i thought through an adapted flywheel), the box wont affect things especialy when not in gear.
19th Jul, 2007 at 02:29:58pm
I think he's more worried about somwhere for the oil to sit.... AlexF |
Site Admin ![]() 9407 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
19th Jul, 2007 at 02:41:08pm
don't you leave it all as it is, and just pull the flywheel? On 15th May, 2009 TurboDave said:
19th Jul, 2007 at 05:13:01pm
as above,thats how the dyno at uni worked. "Turbo's make torque, and torque makes fun"
