| Home > Help Needed / General Tech Chat > Need advice on flashing a megajolt | |||||||
15th Jul, 2007 at 12:00:58am
Hi ive downloaded the latest megajolt files, as its still freezing on any pc when in runtime mode.
15th Jul, 2007 at 09:51:37am
What freezes?
AlexF |
15th Jul, 2007 at 12:30:06pm
the software does, and have to ctrl alt delete it each time. Been recommended on their forums to flash the megajolt, how do i do it? I have all the files Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
146 Posts Member #: 1092 Advanced Member Yours from the Funny Farm |
16th Jul, 2007 at 07:35:56pm
you position yourself in front of it, get ready, pull your pants down real quick,pull em back up pronto and run like hell!!!
Warning:Stig in Training
17th Jul, 2007 at 10:50:57am
:S Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
17th Jul, 2007 at 10:51:23am
:S very confused!
17th Jul, 2007 at 11:18:10am
Try a different machine if you can! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
18th Jul, 2007 at 11:35:21am
yep have done, and tried the same laptops on another megajolt in a triumph and all works fine. its all down to the megajolt, probably just needs flashing, when i find out how! :) Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
18th Jul, 2007 at 11:55:06am
Have a look on autolabs AlexF |
567 Posts Member #: 102 Post Whore Pennsylvania USA |
18th Jul, 2007 at 11:58:11am
Hey Feebs
18th Jul, 2007 at 01:07:29pm
Everything i could find about flashing on there was far too technical, about flashing individual chips or changing capacitors
download hc08sprg.exe from the downloads section and the latest firmware as well mjlJunior.s19
connect the board with the chip on it but leave powered off go to a command prompt an change to the directory that you saved the 2 files to. Type the following command line, it presumes that you have the board attached to com port 1 "hc08sprg 1Confused 9600 mjlJunior.s19" For com port 2 use "hc08sprg 2Confused 9600 mjlJunior.s19" You should now see the following "Waiting for HC08 reset ACK..." Now power up the board and you shold see a load of stuff followed by: "Are you sure to program part? [y/N]:" Obviously now you choose Y or N, presuming you choose Y you should now see: "Memory programmed: 100%" Jobs done, this is whaat i just did on mine and all seems ok so far, own risk, no reponsibility etc etc etc etc etc as usual! Edited by jamesfawcett on 18th Jul, 2007. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
18th Jul, 2007 at 02:07:58pm
Whats wrong with the instructions>?< AlexF |
18th Jul, 2007 at 04:29:12pm
Seems straight forward from a computer illiterate point of view aswell..Lol https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
22nd Jul, 2007 at 07:30:01pm
What does saving the map to flash memory actually do over leaving it in RAM?(computer illiterate question) 'Where does the engine go?' |
22nd Jul, 2007 at 10:12:31pm
RAM is volotile which means when it loses power it loses whatever is in there. Just like a PC has a hard drive to store the OS. |
