Home > Help Needed / General Tech Chat > downpipe spring
Mark1275GT
Member #: 886
London.
More problems lol
How do i get that spring off the downpipe, working from under the car.. any tips. :) cheers..
why?
normally stays on as it doesnt let the ball come apart anyway.
Mark1275GT
Member #: 886
London.
Im fitting a new single 2"maniflo Exhaust system, and i cant take the old Middle Pipe away from the down pipe, As it's hard to pull off working under The car On ya jack jones, if u get My Drift. *tongue*
So i though i'd take the spring off to Make life easyer for me.
Anyway, i take it that that's not a good Idea.
So, any idea how i can get the blimy Thing off :)
Cheers :)
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
pliers!
AlexF
Mark1275GT
Member #: 886
London.
Tried that, doing that from under the car is a nightmare, it's hard to do.
Any never mind :)
Thanks
t3gav
Member #: 229
Gavin@minispares.com
kent
Take the whole exhaust off and then just stand over it and pull it off :)
Carl
Member #: 95
liverpool-on-sea
id take the complete down pipe off with the exhaust then split it probably be easier.
the clamps not difficult if you weld the bolts onto onside when its off
Angle grinder. And replace with a conventional spring!
Mark1275GT
Member #: 886
London.
I cant for the life of me take the clamp Off where the down pipe starts from Inside the engine bay. it's well tight..
So my Only option is to do what dave Says, And grind the spring off.
That make my life alot easyer :)
Any off these springs do the job ?
http://cgi.ebay.co.uk/Small-SPRING-SET-ext...bayphotohosting
Cheers :)
Mark1275GT
Member #: 886
London.
Ive ginded the spring off, hoping to take that little bit of pipe that joins the down pipe off. it's like a kind of half ball on each the down pipe and the other little pipe, one part over the other. now how do i get this off please. if you say you cant take it off, then ive grinded the spring off for nothing lol..
Im leaning as i go along..
Cheers for your help ppl..
The downpipe ball does not separate. You disconnect at the turbocharger.
as in the knuckle wont come apart even when the spring is off?
could be carbon build up? or it might just not be made come apart without destroying it?
Ive managed to take one apart........it never went back together again though! *laughing*
Mark1275GT
Member #: 886
London.
lol wished someone told me that before i grinded the spring off lol i thought it come away.. anyways that's another leason ive learnt, as im still learning as i go along.. right then lol, where the down pipe goes up into the engine bay, there is a clamp, and i cant get the bloody thing off, no room. so im gonna lift the engine up a bit, so i can get to the clamp better...
Cheers lads :)
Turbo Shed
Member #: 30
Epsom, Surrey
you cant get the clamp off?
all you have to do is put your hands down the back of the engine and undo the clamp. should be a couple of 1/2" or 13mm nuts and bolts.
if you think undoing them is hard you should try putting it back together!!!
to re-assemble, hold exhaust with one hand, then hold the clamp with another hand and feed the bolt in with another hand and fit nuts.
so all you need is to grow 1 or 2 more hands and fit them all down the back of the engine!!!
graemec
Member #: 1424
Carnforth, Lancs
Someone did tell you the ball wouldn't split: Iain, in the first reply to the thread.
LOL!
when you put it back, slide a trolly jack under the down pipe and jack it up till its a bit lower than the manifold, then with your hand down the back of the endgine lift the down pipe into place then jack the jack with your foot untill it just holds the down pipe in place, then you are free to use 1 hand to hold the clamp in place, 1 to put the bolts in and 1 to do them up*wink*
Turbo Shed
Member #: 30
Epsom, Surrey
nah, grow another hand sounds better!
I always put wooden blocks under the exhaust to hold it in place, this arm growing business takes too long...Lol
Mark1275GT
Member #: 886
London.
All sounds good to me.. :)
Cheers..
t3gav
Member #: 229
kent
Or do as Carl said and weld the nuts onto the clamp :)
Star Mag
Member #: 375
Leicestershire
I have found that taking the the engine steady off the side gives a little more room to get your hands in and a stubby/cutdown spanner does the job! on the clamp i welded some lengths of threaded bar into the clamp helps and just putting the nuts on makes life easier!
Mark1275GT
Member #: 886
London.
Yes your right. my silly mistake *blush*
