| Home > Help Needed / General Tech Chat > crank need a grind? Block ok to use? | |||||||
17th Jul, 2007 at 09:04:52pm
I am thinking of throwing a turbo engine together from an assortment of parts I have lying around.
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
17th Jul, 2007 at 09:13:37pm
Id get the crank ground and it might be worth getting the block honed at an engine workshop.
Back once again like a renegade master |
17th Jul, 2007 at 09:22:35pm
The block will need a rebore then, It has already been honed to the maximum clearance.
17th Jul, 2007 at 09:25:31pm
Try getting the crank polished, then if that doesnt sort it, grind it.
I seriously doubt it! |
17th Jul, 2007 at 09:44:21pm
are you telling us you paid someone to hone the block and he left it with half a job done,
18th Jul, 2007 at 09:16:38am
Looks like I'm an idiot for accepting the block, it has been honed by 0.005 (live and learn)
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
18th Jul, 2007 at 10:39:44am
if its just the block out of the buch of parts just rebore & put a shout out for some good 2nd hand pistons, worth a bash! SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
18th Jul, 2007 at 11:39:38pm
On 18th of Jul, 2007 at 10:39am clubminiflip said:
if its just the block out of the buch of parts just rebore & put a shout out for some good 2nd hand pistons, worth a bash! Plus more power!!!!!!! LOL Back once again like a renegade master |
19th Jul, 2007 at 04:17:30pm
I've just had another rummage in the garage and found another standard size block, I just checked the ring gap and the block appears to be unworn - also original honing marks still visible. so a slight witht the honing machine to deglase the bores should do the trick nicely.
