Home > For Sale > Morspeed Booster Super Squish 4
I have a Morspeed Booster Super Squish 4 head for sale, Serial number MSPD 151.
It is the 36mm inlet and 30mm exhaust version.
I'm selling because (whatever Morspeed say) this head is NOT suitable for small bore engines, owing to the chamber shape it has a tendancy to fail head gaskets on small bore engines. It would be ideal for moderate to massive power on large bore engines.
It's has been on my hillclimber for one season and has covered no more than 200 miles.
Chambers are 27cc.
New these are £530 (check the website for spec and price http://www.morspeed.co.uk/miniheads-booster.htm )
I'm after £300 plus postage
Nick
Member #: 154
Midlands
wil, perfect timing dude. can you give me a couple of days to see if i can get the pennies please?
just found this on my head...
OUCH! :(
well the Benross head makes more power wil .....lol
155BHP and........................
13.5 1/4 Mile on a 998
BUD666 is there nothing that can be done about your head??
Steve??
As the pin hole is "outside" the valve seat, have it drilled and welded. I've had heads welded, and this has worked brilliantly. Cheaper to try than a new head anyway!
Also Bud, have the valve seats ground properly, and not with a 5mm wide 45degree cutter. Get some proper 3 angled ones. Seriously :)
budd i think this head may be salvagable, ii can have a go for you
hope its not a cavern behind the pinhole
Nick
Member #: 154
Midlands
well its the same in number 1 and number 3 so i'd guess the others aren't far behind. a mate has offered to have a try welding it up for me so i'm going to pass it on to him and see if he can salvage it. if it works then i can choose which head to use and sell on the other one, but seeing as the car is also my daily drive i need to get something sharpish :(
I see. There you have it for not using coolant you stupid English people! *wink*
All blocks and heads I've got from England have been VERY rusty on the inside. I guess an old English Mini would take an extra quart of coolant over original!
Honest :)
Vegard is right!
the amount of Imp heads I've seen that are shagged due to no antifreeze or inhibitor......
slammed 66
Member #: 835
Grimsby N.E. Lincs
Wwhen you say small bore, do you mean stock 1275 or 998?
Also whats the best price you could do on it?
Has it killed headgaskets with you and finally, what boost would you recommend running on standard pistons?
Thanks
Ross
1986 renault 5 gt turbo
1989 Renault extra
1991 R32 GTR
1998 Mini MPI
1999 Nissan Elgrand
Small bore means 998cc.
slammed 66
Member #: 835
Grimsby N.E. Lincs
no good for a 1275 then :(
1989 Renault extra
1991 R32 GTR
1998 Mini MPI
1999 Nissan Elgrand
clubminiflip
Member #: 54
nr coventry
will h's head is a 1275 940 head that he used on his superb hillclimb car, fine for any other turbo 1275 just not his uber fast thing! pretty sure its a 940 large bore head
budd those pinholes should weld ok! now i've seen the pic i see what ya meant! weld is harder than cast iron so recut the seats as vegard say's & should be good as new!
if the other seats go when the new seats are cut weld um up n do the same, cheaper than a new head & what ya have was givin the figures!
cheers for the bits by the way, thumbs up arrrh! thats me trying to be a bit brummie! *happy* big thanks!!!!!!
Edited by clubminiflip on 3rd Aug, 2007.
What? Read the advert, it says that the head is not suitable for small bore engines e.g. 998, so therefore it is absolutely fine for a 1275 engine.
Either way it's sold.
