Home > Help Needed / General Tech Chat > quicky whats that tool thing called for cc head chambers i cant remeber?????
clubminiflip
Member #: 54
nr coventry
is it called a burrette or a pepette i was gonna have a look on ebay or would somewhere like cromwell tools do them?
my head is working out to be around the 26cc mark doing it with a syringe but i'm not confident in its acuracy, this gives me a 8.3.1 c/r which is a lil low but do-able, i could skim the head to bring it up
cheers
Edited by AlexF2003 on 19th Jul, 2007.
birette or something like that, you know what i mean, i i know what you mean
clubminiflip
Member #: 54
nr coventry
should be called a liquid chamber volume checker i reckon lol *happy* an lcvc
cheers nic *tongue*
pipet, or sometimes called a burret
a syringe is very accurate, i can assure you
but if you want someting like i use in graduations of 0.1 cc then search for one
ML, milliliteres are correct to the last sixth decimal point to CCs
hope this helps
clubminiflip
Member #: 54
nr coventry
the syringe i'm using is "ok" it's the fact thats its difficult to draw the oil out of the head chamber, theres that last bit in the bottom i cant get, the one i have is a 50ml medical syringe with 1 ml graduations, if i can get a decent burret or pipet then i'll do so, maybe the oil i'm using is too thick
like the operator lol *tongue*
use turps and or oil mixed
why you need to remove the oil ???
fire the oil in and see how much you have in the chambers then dump it
using a peice of perspex with a 8mm hole in covering each chamber at a time
use grease to make a seal and use your finger pressure applied to make sure
hope this helps
clubminiflip
Member #: 54
nr coventry
arrrrrrrhhhh thats the way ar ha ar ha i like it ah ha a ha hehe i'll do that mr steve, mix some turps in there, i have a spare shitty cd too! right then, an acurate result for my C/R 2moz i hope :)
with 26cc chambers i worked out i'll be getting 8.3.1 which is a lil low aint it but i've put 2.5mm for the gasket & i can skim the head to correct it anymore cant i?
LIke i said pal. Just crank the boost up lol!
So, no correct answers yet, I'll try.
Burette!
danboy
Member #: 1381
I think a Burette is a graduated glass cylinder with a tap at the bottom to allow fluid to flow.
A pipette is a graduated glass cylinder without a tap, fluid is allowed to flow by removing your thumb from the top of the cylinder.
A Burette will be the easiest to control and should be the most accurate.
A suitably graduated Syringe should be the next most accurate followed by a Pipette.
Regards
Dave
clubminiflip
Member #: 54
nr coventry
mike "crank the boost up" lol thats my nxt opton t list i tell ya hehe! *happy*
jonspeed are selling these (vegard came 1st in the spelling of it correctly so can claim a free choccy bar frm turbodave *happy*) burette's from 29-33 squids!
i'll try my syringe again today with a benross-thin-oil-mix in it, try n nail this C/R bugger
quite excited doing this *happy* sad i know!
Edited by clubminiflip on 19th Jul, 2007.
1380turbo
Member #: 1211
Working up the BHP ladder.
I'll go for a 'brunette'? Wanna get in before Nic *wink*
Sure its a pipet
this is a burette,
this is a pipette,
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
If a syringe was inaccurate is would kill people!
AlexF
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
btw
www.afracing.com/cr.xls
SHAMLESS PLUG!
AlexF
clubminiflip
Member #: 54
nr coventry
from my original chks i'm coming up with 8.3.1 thats with
26cc chambers
998 .20 pistons+1014cc
copper 998 gasket, i've put this at 2.5cc
standard stroke
6cc dished pistons
a lil ow really i thought
i'm re-checking the cc's of the chambers & pistons as wee spk
clubminiflip
Member #: 54
nr coventry
done my chks & its coming out at 26cc's on my head, if i wanted to raise the C/R how much would i need to skim the head to make it 8.5.1 or closer to 9-ish, or should i work with what i hae at 8.3.1, i know this seems to work on 1275 turbos ok but on a small bore, i'm planning to drive it most of the time at 8-10 psi, whats your opinions chaps, i'm nearly ready to put my head on the block but i'll hold off n get it skimmed if the genural concensus is what i have is too low!
cheers all
are there any thinner gaskets?
miniminor63
Member #: 672
The oversills police
Oslo, Norway
are the pistons flush with the deck?
clubminiflip
Member #: 54
nr coventry
right just been chkin again on my new aldi digi vernier calipers haha *happy*, i have 2 gasket types, i have a 3rd but cant find it at the mo
my payen AF copper gasket is coming out at 0.88mm when chked on all for sides
my cheapo 998 head gasket is coming out at 1.45mm on all sides, looking a lil brighter
thats brought me to around the 8.4-8.5 C/R mark
clubminiflip
Member #: 54
nr coventry
oh yep 4got, the pistons are flush with the deck, looks quite spiffy to me this engine lol
i am a plonker! trust me know
clubminiflip
Member #: 54
nr coventry
8.5 C/R should be ok i'm thinkin with 10psi & intercooler, i'm thinking this should work ok, any opinions chaps, should have the short block ready bar the belt drive kit 2moro (gotta pick up some seals) funny this C/R lark, i understand it more now!
what a fricken novice lol *happy*
miniminor63
Member #: 672
Oslo, Norway
what happened here? the post got added in another post than the one I replied in???
Edited by miniminor63 on 20th Jul, 2007.
mini13-in that pic library of yours do you have any brunettes?
