Home > Help Needed / General Tech Chat > oil drain plug threaded
Some tit has threaded the oil drain plug on the metro which it turns out is the cause of the oil leak.
It can be done up only slightly tight before it begins to spin while getting no tighter. Does any company offer oversize drain plugs or how do I solve this problem?
Failing that what can I use to seal the gap. Instant gasget doesn't work.
Thanks
Nick
Member #: 154
Midlands
needs to be helicoiled dude, go see your local gearbox specialist they should be able to sort you out.
Minispares do an oversize taper plug that will screw in and form its own thread.
