| Home > Help Needed / General Tech Chat > K&N air filter question | |||||||
158 Posts Member #: 551 Advanced Member Ashington W.Sussex |
25th Jul, 2007 at 05:47:01pm
I have just ordered a 1 metre 57mm air pipe to go from turbo to filter and now want to buy an air filter to match. I'm after a K&N filter but notice that when buying, they only specify the id of the filter neck. As the pipe clamps to the outside of the filter neck, can anybody tell me the thickness of the rubber neck bit so I can workout from the id the right size to buy.
25th Jul, 2007 at 05:54:17pm
i would get a GREEN cone shaped airfilter from Avonbar!
25th Jul, 2007 at 05:58:28pm
ok, cheers for the info!
25th Jul, 2007 at 06:05:39pm
the green filter is 58mm inside Dia but the rubber is quite soft and will easily sqash over and make a perfect seal Edited by BENROSS on 25th Jul, 2007.
144 Posts Member #: 1677 Advanced Member Netherlands, The Hague |
26th Jul, 2007 at 09:53:30am
Read all about them:
26th Jul, 2007 at 10:11:35am
On 25th of Jul, 2007 at 05:54pm BENROSS said:
these flow 240 bhp with no restiction ooops I'd better get a bigger one then! On 15th May, 2009 TurboDave said:
26th Jul, 2007 at 12:49:24pm
Well then I could probably cut mine in half, no a third and still get results! On 7th Nov, 2008 Nic said:
82 Posts Member #: 939 Advanced Member |
26th Jul, 2007 at 02:35:25pm
ooops I'd better get a bigger one then! 8)
26th Jul, 2007 at 08:44:05pm
tazzy thats not the right link for the filter
26th Jul, 2007 at 09:10:04pm
I don't personally trust any sponge / foam filter... I'll always pick a K&N. On 17th Nov, 2014 Tom Fenton said:
26th Jul, 2007 at 11:54:52pm
sponge / foam filter as dave says
27th Jul, 2007 at 07:48:56am
I don't see how a foam filter can filter at all, some of them you can see through! Cotton gauze and oil is what you want. On 7th Nov, 2008 Nic said:
27th Jul, 2007 at 01:19:42pm
Usually I would agree, but the DON has a foam ITG filter on, it really is a good bit of kit.
27th Jul, 2007 at 01:52:18pm
27th Jul, 2007 at 02:16:58pm
On 27th of Jul, 2007 at 01:19pm Tom Fenton said:
Usually I would agree, but the DON has a foam ITG filter on, it really is a good bit of kit. Your right, the ITG seems to be the aception. On 7th Nov, 2008 Nic said:
27th Jul, 2007 at 03:20:46pm
Well, any filter is better than none - and I'm sure Avonbar wouldn't sell junk.
27th Jul, 2007 at 03:28:56pm
