| Home > Help Needed / General Tech Chat > need help fast please! | |||||||
9th Jun, 2004 at 11:46:36pm
hello again, just have a quick question about engine steadies, i have a lower engine steady on the front left lower subframe which goes to the clutch casing, but i need the bracket and bolts etc, all the shops seem to sell are the stabilizers which go to the rear of the subframe any ideas? cheers gav |
10th Jun, 2004 at 07:22:04am
go to a breakers yard, or ring minispares, or a mini company who brakes minis On 15th May, 2009 TurboDave said:
10th Jun, 2004 at 07:43:46am
The one to the rear of the subframe is vastly superior to the std (forwards pointing) one...
10th Jun, 2004 at 08:24:40am
any one got a pic of how the lower rear subby to engine steady is fitted?
AlexF |
10th Jun, 2004 at 08:29:46am
Alex - the bracket is pretty similar to the 'front' bracket, but the actual tie bar itself has the ends twisted at 30 degrees (or so) to each other, such that it lines up with the subframe angle. You need to drill a hole in the double skinned section of the subframe just to the rear of the lower suspension arm On 17th Nov, 2014 Tom Fenton said:
10th Jun, 2004 at 09:51:07am
arr that makes sence...
AlexF |
10th Jun, 2004 at 10:18:56am
10th Jun, 2004 at 10:23:39am
good good :)
AlexF |
