Home > Help Needed / General Tech Chat > clutch arm query
I am busy converting the metro engine to fit the mini and am confused about the clutch arm.
The pre verto's obviously have a massive long arm (I think)
The vertos have a short arm
However the clutch arm on the metro engine seems to be sort of in between the two, not short or not long.
What slave cylinder do I need to use for this arm and also will a turbo clutch plate fit without hassle?
A basic question I know, but its kind of thrown me because I have never noticed a medium length arm
Thanks
That is a cable type clutch arm as used in later metros that use a cable clutch. Remove it and throw it in the bin, its no good to you.
You need a verto type arm (short type) and also the bracket for the slave cyl.
you have the arm for the metro cable clutch.
you need either the verto arm if you have a verto flywheel or a long non verto arm if you are changing to a nonverto flywheel.
you'll also need the plate for the slave cylinder to bolt to for the verto.
