Home > Help Needed / General Tech Chat > bulkhead box bananza !
Arge
Member #: 290
Basingstoke, Hampshire
I am currently around halfway through my mini turbo project and am after some advice...
The car is in the "shell" stage at the moment but i am planning ahead as to what engine i would like. I have decided it has to be a turbo (for obvious reasons !) and due to the limiting factor of the mirage manifolds, i want to fit a bulkhead box .
my questions are as follows...
1. Does fitting a bulkhead box reduce the strength of the bulkhead a lot ?
2. Would fitting a roll cage counter this weakening ?
3. Not knowing exactly what set up i will use, i want to fit a bulkhead box that will fit all possible setups ( t2,t25,t3 - metro manifolds, other manifolds etc.) Which box does everyone use or do you all make your own ??
Thanks
Ryan
Will my project ever be finished !!? hopefully you guys can help !
Its only been like 10 years in the making and I'm only just assembling my engine!
1) Not especially, as long as it is welded in to a good standard. I've certainly never known anyone have a problem.
2) Not really, it does nothing to brace the bulkhead. You are better off fitting solid mounts to use the subframe to brace the bulkhead. You can also bolt the subframe through below the bulkhead box if you wish.
3) Any of the boxes you can buy will do the job. There is a guy on here does them.
Edited by Tom Fenton on 29th Jul, 2007.
Arge
Member #: 290
hey thanks Tom,
What do you mean when you say "bolt the subframe through below the bulkhead box " ?
do you mean fitting a solid spacer between the subframe and bulkhead and bolting through it ? do you have any pictures of this modification ?
Also, any ideas who it is on here who does the bulkhead boxes ?
and lastly, what thickness of meterial should be used for the boxes, i would assume it should be fairly substancial ?
cheers
On 29th of Jul, 2007 at 05:59pm Arge said:
1) do you mean fitting a solid spacer between the subframe and bulkhead and bolting through it ?
2) do you have any pictures of this modification ?
3) Also, any ideas who it is on here who does the bulkhead boxes ?
1) Yes
2) No
3) milamber
You are in luck, I have found one.
JT
Member #: 637
Hertfordshire
milamber does the box's top work he does as well.
give hime a pm im sure he will sort somthing out.
cheers
josh
My build thread..
What do you mean? Limiting factor?
*smiley*
Thanks
Ryan
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Got some new improved bulkheads available. Just pm Arge
Cheers Josh...wheres my instructions! :)
On 19th Jan, 2010 wil_h said:
JT
Member #: 637
Hertfordshire
hopfuly if the weather stays good it will be done soon!
i need to get me dad to weld it in as im not very good at mig welding yet! need more practice. lol
My build thread..
Jason G
Member #: 1459
En-suite user
Braintree, Essex
No probs, just take some pictures m8
Monster22
Member #: 39
heres mine, made it myself 1.5mm thick sheet seem welded.
Edited by Monster22 on 31st Jul, 2007.
I'm worrying about that corner on the right sticking out buddy. I've a fair suspiscion that the air intake pipe won't get past that.
Heres Mine Also made it myself
Monster22
Member #: 39
Thanks Tom, will bolt the subframe in tonight and hang the engine in place :( thought I'd got it right, never mind. Have to get the electric glue gun out Thanks for the spot.
M
Monster22
Member #: 39
Just back to your questions....I'm seam welding as much of the shell as possible so I don't need a rollcage. Insurance was a big consideration in my thoughts.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Good job 1573wx :)
If your turboing it.....I think a roll cage is the least of your probs with insurance. *wink*
clubminiflip
Member #: 54
nr coventry
on this subject & slightly off it, would you guys think it a problem to have a turbo box & a weber box (or should i say upsidedown battery box) structually speaking, my welding is pretty good on the mig & i nkow jimters & 1573wx's minis have the whole thing cut out in the top firewall area, anyway you lads of experiance know what i mean, cheers chaps, good to see some bulkhead box pis so i know where to pop it in, got a better idea now! ths enquiey is cause i'm welding my dads van bk 2gether!!!!
danboy
Member #: 1381
Like this?
regards
Dave
stefaz
Member #: 1656
stoke-on-trent
i have both in mine mate - meant i could change the heat shield without undoing manifold nuts
clubminiflip
Member #: 54
nr coventry
fooookin heck! everyone on here has very big weber box's lol!
thats ok then if its stuctually ok to do!
my dads minivan will e running a weber & i gotta weld the weber box/upsidedown battery box in it & i think he may go the turbo route eventually so gonna put the two box's in, saves greaf & its space thats needed anyhow! not sure where to place the weber box yet but looking at these pics i may get him to purchase another batterybox & weld two 2gether for a double, like danboys for instance! looks cracking, if anyone has a pic of a lill weber box (battery-box size) that would be ace!
wheres that bloody grider again *happy*
I wouldnt worry about it to be honest, loads of people have bulkhead and turbo boxes and have never moaned about about it. Not to my knowledge anyways.
danboy
Member #: 1381
CMF, The reson i did a large airbox was to be able to fit a cold airbox system when running NatAsp, it's also very useful to fit other ancilliaries out of the way. ie fuel filter, washer bottle etc. etc.
Worth doing in my opinion.
Regards
Dave
Deffo, im gunna mount my wiper motor up inside out of the way!
