| Home > Help Needed / General Tech Chat > BlockedBreather ... | |||||||
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
10th Jun, 2004 at 11:52:20am
As you know I have been having some problems with smoking on idle .. TurboLessTosser |
10th Jun, 2004 at 12:47:37pm
where do you think the crank case pressure comes from?
10th Jun, 2004 at 01:58:05pm
So do you rekon then, by correcting the problem with breathers
TurboLessTosser |
10th Jun, 2004 at 02:21:25pm
meybe AlexF |
10th Jun, 2004 at 02:21:42pm
easy test is to take the rocker cover cap off. If it still smokes it's the rings or turbo.
10th Jun, 2004 at 02:23:02pm
that would sure be noisy dave!!
AlexF |
10th Jun, 2004 at 04:27:10pm
will do the test 2nite ....
TurboLessTosser |
10th Jun, 2004 at 07:48:59pm
i had a similar prob and changed the head and that fixed it id tried new stem seals that dint help i fink the guides were worn or summit. after youve checked your breathers etc id try either taking off your turbo or try a different head.
