| Home > Technical Chat > charger pulley system | |||||||
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
30th Jul, 2007 at 07:17:41pm
I've got all the parts for the supercharged engine im building for a friend. Crank, block and head are on the way and should be back soonish so my attention has turned to the drive system for the charger.
31st Jul, 2007 at 01:23:32pm
What kind of pulley is it you need (e.g. belt profile etc)?
31st Jul, 2007 at 01:39:04pm
One thought I had when thinking about this was that, if you use a 36 tooth drive pulley on the engine, you could remove a small piece of one tooth to give just what you need for Megjolt. (assuming you use a steel pulley)
31st Jul, 2007 at 04:43:09pm
Are you sure you need a 1:1 ratio?
194 Posts Member #: 1296 Advanced Member Milford Haven Pembrokeshire |
1st Aug, 2007 at 07:17:47am
Mine's fitted with 8M timing gear, belts avaliable from powerscoots, its an omega optibelt and comes in a loads of different lengths.
1st Aug, 2007 at 11:20:09pm
On 31st of Jul, 2007 at 04:43pm mini13 said:
Are you sure you need a 1:1 ratio? without knowing what youre intending to with it i'd guess you'd be looking at around a 1.5:1 ratio. (1293 10 psi boost ect) heres a useful calculator i found a while back... http://www.sprintex.com.au/files/Blower_Calculator.xls its a 998 :) I've seen the future and tbh its Pie
1st Aug, 2007 at 11:20:58pm
On 31st of Jul, 2007 at 01:39pm danboy said:
One thought I had when thinking about this was that, if you use a 36 tooth drive pulley on the engine, you could remove a small piece of one tooth to give just what you need for Megjolt. (assuming you use a steel pulley) Regards Dave I have to say thats a pucking good idea! I've seen the future and tbh its Pie
1st Aug, 2007 at 11:22:07pm
On 31st of Jul, 2007 at 01:23pm matty said:
What kind of pulley is it you need (e.g. belt profile etc)? There are plenty on the UK. I used one called HPC Gears, found them really easy to use, and they can make one-offs. www.hpcgears.com If you search on google try typing "gear" into the search as well as pulley as it brings up alot more companies. ![]() I found the HPC place beofre, i'll give them another shout as i didnt get much from them the first time! Cheers! I've seen the future and tbh its Pie
2nd Aug, 2007 at 08:21:52am
ahhh 998, makes sense now!
2nd Aug, 2007 at 10:38:27am
Hows about this place then?
2nd Jun, 2009 at 03:09:50pm
Time for some post excavation....
2nd Jun, 2009 at 03:38:25pm
PM Fastcarl.
2nd Jun, 2009 at 03:49:07pm
Will do, thanks On 11th Feb, 2015 robert said:
3596 Posts Member #: 655 Post Whore Northern Ireland |
2nd Jun, 2009 at 03:53:26pm
CDF Racing also makes pulleys 9.85 @ 145mph
