| Home > Help Needed / General Tech Chat > mbcs rule ok | |||||||
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
11th Jun, 2004 at 12:30:58am
Chaps TurboLessTosser |
11th Jun, 2004 at 12:39:47am
i want to know this also! i thought it was just like fitting a 9psi actuator.
11th Jun, 2004 at 07:05:53am
tis tru I am confused Fastest 998 mini in the world? 13.05 1/4 mile 106mph
19 Posts Member #: 169 Member |
11th Jun, 2004 at 09:38:36am
The way I understand it is that Yes this will happen. but maybe not quite as much as 0.1 psi. and your really not goning to notice much difference between 9 & 8.9 Psi.
![]() 164 Posts Member #: 206 Advanced Member Milton Keynes |
11th Jun, 2004 at 09:38:50am
Sounds about right to me 9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked |
11th Jun, 2004 at 10:18:37am
great stuff! I have mine with quite a bit of length on it, it goes from the turbo area up to the bulkhead where ive mounted it next to the wiper motor, wanted to keep it away from heat and somewhere to get access to it, should it be ok with all tht length? Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
11th Jun, 2004 at 11:01:46am
Shouldnt be a problem, although in theory, I guess the closer you can get it to the actuator, the better, althoug I would imagine, in practice, it would be nigh impossible to tell. 9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked |
![]() 1128 Posts Member #: 142 Post Whore Winchester |
11th Jun, 2004 at 12:38:40pm
what would happen if you had a 10psi actuator and the mbc set to less than 10psi, say 8psi for example, would the boost be 8psi or would the fact that there is a 10 psi actuator mean that this is the minimum boost.
11th Jun, 2004 at 01:20:06pm
Yes, 10psi would be the minimum. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
11th Jun, 2004 at 06:12:57pm
haha this is getting mad Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
