Home > Help Needed / General Tech Chat > Fitting Hi-Lo 's on the front w/o a cone compressor
I was told buy a reputable mini nut, that you can fit front hi-lo's without using a cone compressor.
Any idea how you would do this?
rears yes, but not sure about the fronts, infact im pretty sure its not possible....
Mini_Andy
Member #: 432
impossible imo
stefaz
Member #: 1656
stoke-on-trent
possibly with very old sagging cones, but not with new ones or coil springs.
Mini_Andy
Member #: 432
actually just re-read your first post, you can fit front hi'lo's without a compressor, the trouble comes when you have to remove the old setup before lol
Remove the top Arms?
Jackman
Member #: 984
Westhoughton, Bolton
Ive done it, you just have to remove the top arm... its not easy but it is possible.
Manchester Minis
Top arms off it is then!
Do you think that the compressed cone will make it difficult to remove the bolt?
no it should be quite easy still.
Jackman
Member #: 984
Just keep the arm in place so its straight then pull out, the arm will drop removing the cone.
Manchester Minis
Great!
Thanks guys
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I did it with an old cone when the thread striped so I couldn't use the compressor. I cut part way through the trumpet then chiseled it a bit until it colapsed. Maybe not the safest but as I say my cones were pretty old and had sagged.
On 7th Nov, 2008 Nic said:
naeJ
m
