| Home > Help Needed / General Tech Chat > Spec of a mutro pump | |||||||
8th Aug, 2007 at 10:01:45am
I've been having issues of fuel starvation.
8th Aug, 2007 at 10:26:38am
What exactly is the fuel starvation problem?
8th Aug, 2007 at 10:33:16am
Iain, are you using a red top type battery?
8th Aug, 2007 at 10:39:46am
metro pump is good for power figures a shade under 500 bhp
8th Aug, 2007 at 10:59:06am
Basically after a hard run of about 1-2mins it starts to run lean and splutter, go easy and its fine, let it idle and you can go for another short hard drive.
8th Aug, 2007 at 12:06:17pm
if it helps my metro pump put out 500ml in 11 seconds when i was testing if it was flowing enough. On 20th Oct, 2015 Tom Fenton said:
8th Aug, 2007 at 12:39:28pm
bud, was that via the return or just straight from the outlet?
8th Aug, 2007 at 01:15:40pm
that was out of the feed, just took it off the carb so after the reg aswell. was just with the ignition on so 12V not being charged. On 20th Oct, 2015 Tom Fenton said:
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
8th Aug, 2007 at 02:46:22pm
12.8v from the alternator is v bad, maybe start simple and sort this? I've seen the future and tbh its Pie
8th Aug, 2007 at 03:34:19pm
On 8th of Aug, 2007 at 02:46pm andeh said:
12.8v from the alternator is v bad, maybe start simple and sort this? This will not be thw problem though. I run my car on battery only and have no problems. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
10th Aug, 2007 at 09:35:25am
its not bad for the size of the alternator trust me |
10th Aug, 2007 at 11:28:17am
Works well on a small digger though ay! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
10th Aug, 2007 at 11:38:10am
Yup!
10th Aug, 2007 at 12:41:38pm
We did have a similar problem on the TT. We had a big volt drop through a relay that had worn. When we put a wire in that bypassed the relay you could hear the pump speed up. In the end though we did find that the pump was kaput. http://www.twin-turbo.co.uk
