| Home > Help Needed / General Tech Chat > determining where i'm getting full lift on on inlet lobe number 1 | |||||||
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
9th Aug, 2007 at 07:34:10pm
i've got my basic timing on my non vernier belt drive setup right, i'm now trying to determine where i'm getting full lift on the pushrod in inlet lobe number 1
9th Aug, 2007 at 07:42:15pm
To find out where you are getting full lift, set up the DTI on the inlet pushrod.
9th Aug, 2007 at 07:51:55pm
cheers kean, top man! i confuse myself when i 1st do stuff likethis it seems simpler now, cheers kean thats helped loads!!! SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
9th Aug, 2007 at 08:58:00pm
i've determined i'm getting full valve lift at 109 degrees on number one, i assume i get myself a offset woodruff key now to bring full lift down to 107 degrees,
9th Aug, 2007 at 09:02:52pm
then you buy a 2 degree offset key and insert it in the cam to withdraw the 2 degrees from what you have now:) |
9th Aug, 2007 at 09:05:55pm
i've never seen on so do they just lean one way or another if ya get my meaning? ie if its put in one way it decreases lift the other way increases or am i thinkin a bit wonky lol SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
9th Aug, 2007 at 09:08:13pm
bugger double post sorry Edited by clubminiflip on 9th Aug, 2007. SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
9th Aug, 2007 at 10:06:37pm
correct |
10th Aug, 2007 at 02:59:02am
I have a "timing the camshaft guide" on my website.....
10th Aug, 2007 at 09:35:49am
thankyou ever so much tel, your a star!
10th Aug, 2007 at 09:39:27am
