Home > Help Needed / General Tech Chat > water wetter
n.g.l.
Member #: 181
Chard, Somerset
this coolant additive that lowers the surface tension of the water thus lowering engine running temps. is it any good or is it a waste of time?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I know serval people that sware by redline water wetter...
In theory it should do what it says on the tin :)
Alex
AlexF
n.g.l.
Member #: 181
Chard, Somerset
good cos i can get it really cheap as it is also used in the hydroponics business.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
make sure it doesnt break down at high temps if its not an automotive type...
alex
AlexF
I use water wetter, it droped my running temp by 20 deg, fantastic stuff. not cheap though
Wil
SumpNut
Member #: 28
Its Great! It really works, it dropped my average running temp to well below half on the standard dial,
+ My dad uses it in his MGB v8 conversion still running a standard MGB rad - no fancy v8 rads here, just plenty of water wetter
dan
Member #: 93
yeah it does do the trick, i used to use it in my old five turbo, really did make a difference!!
wow, i alwauys thought that stuff was pants...
I'm going to invest in some for my RR session (the only time my car gets hot)
I asked the guy in the local motorworld for some, "Water wetter, what's that ?" he said, with a smile on his face. It took me a while to convince him i wasn't winding him up. He'd never heard of it.
I don't think i need any in my engine at the moment, i can't get it to run hot enough. Going to have to try a hotter thermostat today. It's running really cool since i did the cooling mods to the block/head.
Phil. *smiley*
dan
Member #: 93
Phil, did you follow the cooling mods that vizard recommends in his bible?
opening out the block where the pump sits?
i can see you've done the block to head loop
what side rad is it your running?
cheers!
T3Tone
Member #: 252
Sunny suffolk
Am i glad to hear all these comments on the water wetter *happy*
Any one know any prices for it cos it seems a very easy and cheap way of upgrading the cooling system for those that do have problems with keeping temps down.
-MINI CLUBMAN 1380 TURBO-
demon tweeks sell it, but it's not cheap
dan
Member #: 93
halfords sell it too, its at least 15 quid i think, i used about a half a bottle when i did my old 5 turbo, good stuff but gets pricey if your draining coolant a fair bit for engine removal etc
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Even anti freeze is price the rate I am going...
three rads full and no running to speak of :(
alex
AlexF
dan- Yes i have modified the block where the water pump goes.
I am running Minispares 2 core rad.
Phil. *smiley*
scott the joiner
Member #: 9229
newcastle upon tyne
Hi sorry to drag up an old thread but wondering if this is still a good option in the aid of cooling thinking about getting some. Is there any ratios for best results, pros and cons ect of the product thanks Scott
Streetscreamer
Member #: 10125
Zoetermeer, The Netherlands
first ensure you are not solving symptoms and hide problems. Generally good flow, timing and mixture will keep temps already ok
