Home > Help Needed / General Tech Chat > can't get past 6500 rpm with turbo
turbo1312
Member #: 64
Hello,
I have a problem with my mini...here is the spec:
1312cc, 8:1 CR, ported head with 31mm exhaust valves, std valve springs, piper phase III cam, big IC, std. t3 turbo. Boost is around 1.4 bar.
The problem with the car is that it pulls like train up to 6300-6400 rpm and than it seems like it loses power. Since I have Phase III cam, I 've expected power till at least 7500rpm.
I also have megajolt on the car and in that area of map (6000 rpm, 240 kpa) I have timing set at 25°.
Also I have tried to take boost down to 0.7 bar and timing up to 27° and i still have the same problem.
I have fuel around 11:1 on wideband so I don't think that is the problem.
what could be the problem? Std. turbo head valve spring? Vibrating crank sensor?
Dangerous
Member #: 417
276 in mine ign timing at approx 16 degrees,.can nearly get 8k(just under 60mph in 1st)
Kean
Member #: 341
aka T2clubby
South Staffs
Whats the rev limit set to on the megajolt, and what is the cam timed in at??
I suspect you are running rich, 11:1 AFR is 0.74 Lambda and widbands sensor acuracy at this AFR is some what vague
I personaly wouldnt be running less than lambda 0.8 or AFR 11.8:1 at the very outer limits
this is your problem ..........#
QUOTE:-- Std. turbo head valve spring?
go with mini sprocket as well
What turbo are you running? could the turbine be resticting the flow of the exhaust gasses?
miniminor63
Member #: 672
The oversills police
Oslo, Norway
On 12th of Aug, 2007 at 01:51pm turbo1312 said:
std. t3 turbo.
SumpNut
Member #: 28
0.25a/r on a standard metro turbo T3 turbine.
Try a RS Turbo Escort turbine, I belive they are in the 0.36 mark, that will give your motor plenty of room to breath
std. t3 turbo.
I must be going blind, they said it would happen.
turbo1312
Member #: 64
You think that turbine housing could be to small?? Did you guys had trouble with that?
Edited by turbo1312 on 13th Aug, 2007.
turbo1312
Member #: 64
But my brother has n/a mini with 276 cam 10.5:1 CR that goes up to 7300 no problem with std. double springs.
but he does not have a phase 3 cam fitted
ditch the phase 3 cam they dont work! only on fully selected engine components and a well thought out parts combination on a hot cooking track motor
ditch the CAM is my advice
you will be getting coil bind with those standard springs and that phase 3 cam
this is where the MAIN problem lies!
go for the phase 2 or N/A mg cam
what size inlet valves are you running, you dont state
are these race valves??
turbo1312
Member #: 64
I have std. inlet valves (33 mm) and 31mm exhaust valves from vw 1.6 TD
there you go, a bad not well thught out combination of parts *frown*
