Home > General Chat > 1100 pistons rings, where can i get some new ones?
clubminiflip
Member #: 54
nr coventry
i'm going to need some rings for a spare 1100, or a set of new 1100 pistons & rings, where can i get or order some even if they come from down under from a reputable person, cheers chaps
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Dont know but i think i need some. LOL
Have you tried minispares. TBH i think they are the same as the 998, just stroke of crank that is differant.
clubminiflip
Member #: 54
nr coventry
thats what i thought but i think there's a differance betweent the height of the piston from the wrist pin to the crown, i'm not 100% on that though!
Depends on the pistons, the number of rings and the gap widths, but a set from a 998 should fit.
998 and 1100 are the same! Period!
benjamin
Member #: 621
nsw austalia
http://www.minisport.com.au/index.htm
hypatec $175AU or sumthin like that
i use up to 10psi boost for 15,000km with no troubles yet
edit, deffo differnet height to 998 but same diameters
Edited by benjamin on 13th Aug, 2007.
1152cc turboed mini clubman, most powerful 1.1L a-series?
http://boostmini.justboard.net/
clubminiflip
Member #: 54
nr coventry
i thought that was the case benjamin, thankyou for that, i knew the bore size was the same but differant pin to crown height, hope yours is going well bud!
Jordan
Member #: 1392
Could still use em though
