| Home > General Chat > k build on a series? | |||||||
969 Posts Member #: 47 Post Whore Not very sunny swanage |
15th Aug, 2007 at 10:11:25pm
any problems with building a k head engine on a a-series as opposed to a+? any downsides etc? ive fallen over a block and was going to start building, but thought i'd better check that there are no downsides to using it as a base!!!!! Are the cranks interchangable, as i dont rate my chances of finding a 'a' crank in useable nick!!?
And on the 7th day........... God created turbochargers! |
15th Aug, 2007 at 10:16:18pm
Oil pumps are slot drive. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
15th Aug, 2007 at 10:20:28pm
I'd use an A+ block personally, its a better, stiffer, block to use as a basis.
16th Aug, 2007 at 07:58:17am
On 15th of Aug, 2007 at 10:20pm Tom Fenton said:
I'd use an A+ block personally, its a better, stiffer, block to use as a basis. I know at least two on this forum that think otherwise, myself and another very distinct member living in the same place:) |
16th Aug, 2007 at 08:04:29am
I'd use an A+ block personally, its a better, stiffer, block to use as a basis. Do you know this for a fact, or is it another myth? I've been told that stiffening ribs are there to compensate for inferior iron. Also, cranks are interchangeable. Everything is apart form the dizzy. Edited by Vegard on 16th Aug, 2007. On 13th Jul, 2012 Ben H said:
16th Aug, 2007 at 08:41:16am
A+ blocks are defintely better, it would have been completely mad to create a new block just for material downgrade ( we talk about iron).
16th Aug, 2007 at 08:41:51am
I'm with the nordish on this one,
16th Aug, 2007 at 09:38:53am
Fab, forgot about it. Will take action tonight if that was what you meant :)
16th Aug, 2007 at 03:36:40pm
16th Aug, 2007 at 04:40:47pm
I should metion I've seen A+ block with not much wear...
16th Aug, 2007 at 05:58:05pm
lol |
16th Aug, 2007 at 07:42:25pm
I wouldnt say the ribs were there to increase the strangth but rather retain the strength where they have removed metal to save on weight, metal and ultimately production cost.
16th Aug, 2007 at 08:59:26pm
Another thing that makes them flexible is the variation in flange thickness facing the box. The S blocks are thinner here, and do also have the tapper chest covers... |
144 Posts Member #: 1677 Advanced Member Netherlands, The Hague |
17th Aug, 2007 at 07:35:20am
I know quite a lot of subaru drivers and they tend to add sleeves to the block to strengthen it a bit. What struck me as odd is that I don't read alot about sleeves in A+ blocks? |
9th Oct, 2009 at 07:45:34pm
On 17th Aug, 2007 Tazzy said:
I know quite a lot of subaru drivers and they tend to add sleeves to the block to strengthen it a bit. What struck me as odd is that I don't read alot about sleeves in A+ blocks? Then you have not been using the search function correctly
veg
