| Home > Help Needed / General Tech Chat > start up problems | |||||||
![]() 68 Posts Member #: 1702 Advanced Member kent |
16th Aug, 2007 at 03:01:17pm
hi guys,
0 -- CASUALTY IN 5 SECONDS |
16th Aug, 2007 at 03:08:39pm
make sure you have 2 independent earths from the body to the engine
16th Aug, 2007 at 03:18:34pm
ok i will give that a go as i think i only have 1 at the minute.
16th Aug, 2007 at 03:37:24pm
ok tried doing the jump lead on the body etc for an earth but still nothing.
16th Aug, 2007 at 03:39:35pm
Is that a' piggy back' style starter motor? In the 13's at last!.. Just |
16th Aug, 2007 at 03:39:42pm
16th Aug, 2007 at 03:44:15pm
i think so yes.
122 Posts Member #: 1812 Advanced Member Live in birmingham and work sheffield |
16th Aug, 2007 at 03:45:04pm
does sound like either starter or earth problem.
Edited by M111KYP on 16th Aug, 2007. |
16th Aug, 2007 at 03:56:33pm
Change the starter for a known good one before you go any further.
16th Aug, 2007 at 04:20:21pm
I am assuming your battery is a known good one and not flat??
16th Aug, 2007 at 04:21:55pm
Are you sure that the solenoid is right? In the 13's at last!.. Just |
16th Aug, 2007 at 04:40:16pm
ok sussed it now.
16th Aug, 2007 at 04:42:45pm
Open the drivers side window so that you can turn the key whilst your head's still under the bonnet? In the 13's at last!.. Just |
16th Aug, 2007 at 05:18:30pm
lol my bad i didnt think i could reach but yup i can sorry.
450 Posts Member #: 449 Senior Member Oxford |
16th Aug, 2007 at 05:27:44pm
I would say you need to check power to the coil. This could be done by checking with a bulb wired across the '-' and '+' of the coil. Turn over the engine it should flash on and off. If not check the bulb lights when one side of the bulb is earthed and the other is on the '+' of the coil. This need to be checked with ingnition on
16th Aug, 2007 at 05:43:06pm
right i have put a volmeter between the + on the coil and an earth and it reads 10.
16th Aug, 2007 at 05:48:25pm
I
16th Aug, 2007 at 06:42:37pm
ok i tried changing the module from the 3 pin to the 2 pin and put spade connectors on instead of the plug.
