Home > Technical Chat > lsd thoughts ??
Seen this on ebay will it fit my box ???
(sccr 4speed jkd with tran x 4 pin diff )
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...562&ssPageName=
Any thoughts on that type of diff
Thanks Rick
AH!! the salisbury, a mans diff,
if its in reasonable nick it will do the business,
the CW looks like it could do with a clean, ,
also i see its had the case chamfered to ease fitment to late cases,
i may be tempted to have a dabble in this myself,
carl
Hands off carl, Dont you think youve enough !!
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
rick I'm sure your not planning on using your car much on the road but a Salisbury diff can be a real handful ... especially on wheels with minimal offset (such as 13x7s or deep dish 10s)
They certainly do the business and I had one in my last turbo but took it out as it made the car undrivable on the rough roads around the costwolds (then again the boost went down to allow the SCCR gearset to be removed and 2 layers of sound proofining went in so the car ended up the exact opposite of what I think your building!!!!)
Roger the car will be used on road but only minimal, dont mind it pulling me around to be honest make me enjoy it more. had a focus rs last year and enjoyd that, i no its not the same but ideas there.
is the lsd picturd all complete obviously and is there anything i should look out for
thanks rick
RogerM
Member #: 1217
looks to be all there mate. It's difficult to tell without opening but they do wear internally. He says rebuilt so that is probably ok.
The only other thing to check is the ramp rates as if it was from a circuit car it may be a bit too brutal for the road!!
Either way buy a larger diameter steering wheel to help hold on to her!!! *wink*
Thanks roger.
danboy
Member #: 1381
Have you fitted this diff yet?
Regards
Dave
No going to be a while , Y ?
I run a Salisbury myself set at 85lbs. AWESOME! Bit of a handful though. I wouldnt have paid that much.
Paul
I wouldnt paul , but did. Got carried away lol
Should be fun.
Rick
Paul
Actually, Ive changed my mind, thats not too bad a price as it has everything with it.
Paul
Think i worked out that diff , cw+pinion , and output shafts would be £700 ish new.
