| Home > Help Needed / General Tech Chat > bloody exhaust clamp! | |||||||
12th Jun, 2004 at 12:29:01am
me again! gonna put the exhaust clamp on tomorow i have the 2" full maniflow turbo system from avonbar and their clamp, anyone know why the clamp is wider at the top/ bottom (depending on which way you look at it) does it fit over the curved part of the exhaust downpipe at the top or sit just under the ridge cos in the haynes manual its does but it doesnt fit straight if you put it under the ridge! if that makes sense! |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
12th Jun, 2004 at 12:36:24am
large hole to the top.
12th Jun, 2004 at 12:39:36am
both parts cheers mate great to no someone else is online |
12th Jun, 2004 at 12:42:00am
no probs Everyone knows that instructions only have to be read if the thing doesn't work....
12th Jun, 2004 at 01:53:06am
im online Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
12th Jun, 2004 at 10:27:05am
Welding the bolts is vital!!
AlexF |
19 Posts Member #: 301 Member |
17th Jun, 2004 at 09:47:14pm
when you put a 2" down pipe on a good clamp to get is one for a citroen from kwik fit but its a good thing if you weld the bolts to one side as it helps when you put it on
18th Jun, 2004 at 08:05:32am
also relieve the bottom hole, the clamp was only made for the metro system and the maniflow downpipe is bigger so the holes not the right size! |
18th Jun, 2004 at 09:24:45am
i think the 'clamp' you buy from Avonbar currently 'IS' designed for the maniflow system - ie 2"? On 17th Nov, 2014 Tom Fenton said:
18th Jun, 2004 at 10:28:07am
i had a feeling it wasnt, not sure though but i know when Keith sent a new clamp for me to use when i fitted his engine i had to take a fair amount of material out of that to get it to fit. Im assuming he got it from a turbo mini specialist although im not sure which one. |
162 Posts Member #: 228 Advanced Member |
18th Jun, 2004 at 10:10:49pm
if it helps anyone i have hust used a clamp and maniflow downpipefrom avonbar and it was fine, but i did order them at the same time so maybe i was sent the matching parts
