| Home > Help Needed / General Tech Chat > Long plenum bolts | |||||||
249 Posts Member #: 513 Senior Member Sheffield |
18th Aug, 2007 at 11:58:08am
Do these thread into the carb with a nut and washer on the end and what thread would they be? A search suggests they're the same as differential housing? |
18th Aug, 2007 at 01:12:06pm
5/16" UNC , Namerick sell them. Edited by Rob H on 5th Apr, 2008. Isambard Kingdom Brunel said:
18th Aug, 2007 at 01:50:52pm
or drill the threads out of the carb and tap the plenum(m10 iirc).....then you can bolt the plenum on from the carb side making it a doddle to fit.
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
18th Aug, 2007 at 04:43:52pm
thats what i did so glad i did as makes taking stuff apart so much easier "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
18th Aug, 2007 at 05:06:04pm
Cheers, I'll drill the threads out then pop to local nuts n bolts supplier. |
18th Aug, 2007 at 11:10:57pm
plenum bolts are 5/16" UNC IIRC 9.85 @ 145mph
5th Apr, 2008 at 06:21:07pm
Here's an alternative solution I came across whilst trying to find some bolts for the modified air in take on the MG.
271 Posts Member #: 1844 Senior Member BURNTWOOD, staffordshire |
5th Apr, 2008 at 06:49:27pm
easy to fit if you've got a carb box fitted LOL |
