| Home > Ebay items For Sale > Front mounted supercharger set-up. | |||||||
784 Posts Member #: 912 Post Whore North Yorkshire |
18th Aug, 2007 at 02:10:01pm
Found this,
I drill holes in everything..! |
18th Aug, 2007 at 02:17:56pm
thats an interesting setup,
18th Aug, 2007 at 02:27:34pm
I think people get a bit carried away when placing adverts.
18th Aug, 2007 at 02:32:22pm
The amazing thing is that he's got it in there with the dizzy in place.
18th Aug, 2007 at 02:58:50pm
Oh yeah,
18th Aug, 2007 at 04:34:18pm
not buying his reason for sale tho. hmmm no longer a series, but still 1.3 turbo.
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
18th Aug, 2007 at 05:27:45pm
Your not buying engine either! Back once again like a renegade master |
196 Posts Member #: 2301 Advanced Member Blackpool , Lancashire |
26th Feb, 2008 at 11:44:11pm
hello im boz :from sunny blackpool LOL
http://s256.photobucket.com/albums/hh167/boz-reb-2303/
27th Feb, 2008 at 01:28:40am
post some pics up dude so we can see what you've got and if there's anything glaringly obvious as to waht could be wrong.
52 Posts Member #: 1655 Advanced Member Norway |
27th Feb, 2008 at 12:55:57pm
I used to play around with superchargers in my Mini before I bought MOT... The link to eBay is not working anymore, so I would like to see some pictures! What kind of charger are we talking about?? A couple of mini-freaks in Norway are putting their chargers in the front...such-through and it works perfectly! But its a smaller charger than the M45. This one gives 0,8 bar:
27th Feb, 2008 at 01:08:31pm
Agree with bud need pics. But blow through setup would be best.
27th Feb, 2008 at 07:18:26pm
27th Feb, 2008 at 07:23:58pm
Have you got the fuel pressure regulator vacuum line connected so that it will overcome the pressure from the blower whilst cranking? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th Feb, 2008 at 07:57:30pm
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
27th Feb, 2008 at 07:59:57pm
is the carb the correct type?
David. |
27th Feb, 2008 at 08:19:52pm
the carbs a hif44.
27th Feb, 2008 at 08:22:08pm
the carbs a hif44.
27th Feb, 2008 at 08:29:47pm
is it a normal Hif44 or a turbo type? which are sealed David. |
27th Feb, 2008 at 08:35:59pm
reply to paul s. yes got the pressure regulator vacuum line connected .
27th Feb, 2008 at 08:54:52pm
27th Feb, 2008 at 08:56:44pm
hi david , as far as i now its a standerd hif44. http://s256.photobucket.com/albums/hh167/boz-reb-2303/
27th Feb, 2008 at 09:10:21pm
if its standard and not the sealed turbo type, i might be hazzarding a guess this is where the problem lays...it is only a guess tho and should wait untill sumone elses comes along to confirm or disregard this David. |
27th Feb, 2008 at 09:32:13pm
the engine came with a sealed type carb but it kept flooding even with a new needle valve assembly in. with just the ignition on it was pumping fuel tho the jet like there was not a valve there. so was changed to a carb i had that was not sealed but did not flood. also i have noticed on the bottom of the charger is a hole where i read some where a valve should be, any one know? also what are the differences between a turbo and non turbo carb is it just the sealed dashpot. cheers http://s256.photobucket.com/albums/hh167/boz-reb-2303/
27th Feb, 2008 at 09:41:17pm
It could be just a case of resealing your turbo carb, the choke seals are notoriuos for leaking as they go brittle with age.
On 3rd Jun, 2005 TurboDave said:
Here is the plumbing side of it for you... Nice and easy there!
You'll need to source a plenum or make one - you'll find information on making a plenum in the 'How To' section - in fact - almost all your answers are in that section. http://www.turbominis.co.uk/forums/index.php?p=vf&fid=5 Edited by matty on 27th Feb, 2008. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
27th Feb, 2008 at 09:48:25pm
