| Home > General Chat > ARP Head Stud Alternative | |||||||
18th Aug, 2007 at 02:36:36pm
Just been brousing photos on Mini7 site and noticed the head studs on this se7en?? Have i stumbled accross a cheap alternative to ARP?? Might be of interest to those of us on a slim line budget. Ie Me.
18th Aug, 2007 at 02:56:38pm
Yuck Bolts!!
18th Aug, 2007 at 04:04:30pm
Corky bell
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
18th Aug, 2007 at 05:17:20pm
capscrews do look more pretty than head studs, but you'd have to re-consider the torque tightening values as a minimum
3596 Posts Member #: 655 Post Whore Northern Ireland |
18th Aug, 2007 at 11:07:53pm
Are the ARP's expensive in the first place ? 9.85 @ 145mph
19th Aug, 2007 at 12:01:54pm
£65 from Morspeed. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
19th Aug, 2007 at 12:26:27pm
can someone remind me what sort of compression these htings run, is it something crazy like 14:1 or is my mind playing tricks again
![]() 520 Posts Member #: 189 Post Whore Norway |
19th Aug, 2007 at 01:46:29pm
MiniSpares got some race head studs wich should be good. At least that is what I am hoping since I have a set redy for my race engine :) www.shag.no |
19th Aug, 2007 at 01:47:46pm
btw, is that picture of a mini7 engine?? What is the regulations on carbs for that serie??? www.shag.no |
19th Aug, 2007 at 03:53:21pm
I think its a 7. Its only using one barrel of the carb, they are allowed to do that. |
19th Aug, 2007 at 05:13:51pm
On 19th of Aug, 2007 at 03:53pm miniminor63 said:
I think its a 7. Its only using one barrel of the carb, they are allowed to do that. Miglias are allowed to do that as well Andrè :) On 13th Jul, 2012 Ben H said:
19th Aug, 2007 at 05:55:22pm
yes but it would not be very clever.... |
19th Aug, 2007 at 07:53:17pm
But what kind of manifoil is that?? www.shag.no |
19th Aug, 2007 at 10:13:06pm
I think it's a maniflow item, basically it's a tubular horse shoe shape which only uses half the carb. Isambard Kingdom Brunel said:
20th Aug, 2007 at 11:53:04am
Yes, its a seven, you can tell by the tyres through the wheel arch on the opposite side of the pic. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
20th Aug, 2007 at 12:02:29pm
That Engine above is in James Coulson's mini7, engine is built by Dave Wells from SH engineering. Dave also used these bolts on the Miglia engines, he told me he has never had a single head gasket failure. Having said that, are ARP head studs needed?? I've never needed them, and I've not had head gasket problems for years. Edited by Jimster on 20th Aug, 2007. On 15th May, 2009 TurboDave said:
20th Aug, 2007 at 12:16:26pm
Im not using them, and had no head gasket problems running 16-18 lbs of boost!
20th Aug, 2007 at 08:39:51pm
I used BK450 and ARP studs....I blew between cyls 2-3 on a regular basis ( say every 5-6000 miles )
