Home > Wanted > Downpipe exhaust clamp
chinlesswonder
Member #: 1192
In the garage......again!!
seeing as Avonbar have sold out and are NLA, i need an exhaust clamp for their downpipe, anyone got one spare , cash waiting?.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
t3gav
Member #: 229
Gavin@minispares.com
kent
Minispares have them :)
the clamp needs modding if you are going to use the 2" down pipe with it
Turbo Dave wrote an article on this
chinlesswonder
Member #: 1192
thanks lads, ordered one from minispares, if anyone else needs one, they only have 3 in stock.
yep, seen the diaghram, will be modding it for a better fit.
chinlesswonder
Member #: 1192
The clamp is already got a large side and small side, i have seen the thread on welding the bolts on to make it easier to it but, can i weld the steel bolts to the cast clamp using my mig? do you not have to use special wire or summat?.
cheers
keith
nothing special to weld with just use your mig as normal but place a few more amps on
Nick
Member #: 154
Midlands
i just used a spare lock tab from the diff housing round the bolt heads, worked a treat.
redwing
Member #: 1574
Malta
Anyone know what the minispares part number is?
will phone for you john see if they have anything left
redwing
Member #: 1574
Malta
PMd Steve - thanks
