| Home > Help Needed / General Tech Chat > please help | |||||||
141 Posts Member #: 162 Advanced Member |
12th Jun, 2004 at 09:38:44pm
i have fitted my dump valve but its not working right. it is conected to the plenum chamber and the hose on the end is t pieced to my boost guage, and the other end goes to a 5 mm tube on the inlet. when i start the engine the boost guage goes down, then into the vacume part and then i rev the engine the boost guage goes up and the dump valve opens and then closes when i let off, pleas can some one help me |
12th Jun, 2004 at 09:50:25pm
you should nto connect it to your boost gauge, have it connected to it's own hose tail going to your inlet manifold On 15th May, 2009 TurboDave said:
12th Jun, 2004 at 09:51:01pm
right ok i will give it a go then let you know |
12th Jun, 2004 at 10:02:16pm
right done that and still the same, it is like the inlet is sucking the dump valve open, what do you suggest |
12th Jun, 2004 at 10:04:18pm
it will do a bit, but when you blip the throttle the dump valve should close / seal On 15th May, 2009 TurboDave said:
12th Jun, 2004 at 10:06:14pm
right im not getting any noise. is a 5 mm hole in the inlet too big for it |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
12th Jun, 2004 at 10:09:04pm
as pistons stuck in air/fuel causes vac ie gauge drops , blip throttle and gauge rises to 0 or just above , lift off and what litle boost you had causes DV to open and so on , or something like that Everyone knows that instructions only have to be read if the thing doesn't work....
12th Jun, 2004 at 10:09:20pm
12th Jun, 2004 at 10:17:43pm
right ok so what is the problem i think something is not working correct |
12th Jun, 2004 at 10:27:44pm
if every time you blip throttle it goes vac, boost , pop or woosh thats right Everyone knows that instructions only have to be read if the thing doesn't work....
13th Jun, 2004 at 12:16:15am
i dont think it is doinf either of those, |
13th Jun, 2004 at 12:51:07am
just to get it right, the pipe that used to go to the ecu is no going to my bleed valve is this ok
13th Jun, 2004 at 02:07:18am
No.
13th Jun, 2004 at 08:10:17am
i looked at that, and i was a little confused. it said remove the t piec that goes between the regulator and the plenum. when i got my turbo unit i hade coming of the t piece that was on the actuator, a pipe going to the actuator and the other pipe went to no ware. can someone help |
13th Jun, 2004 at 08:19:40am
http://upload.altrezia.com/imageviewer.php?i=213
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
14th Jun, 2004 at 08:29:10am
JIMSTER ...
TurboLessTosser |
14th Jun, 2004 at 01:43:01pm
Nope you rnot an arse...
AlexF |
