| Home > General Chat > OT - Running Diesel engine on veg oil. | |||||||
20th Aug, 2007 at 02:31:14pm
We have an diesel genertator in the workshop, 6 cylinder turbo thing, it drinks the fuel.
20th Aug, 2007 at 02:35:51pm
Vegi and mineral oil doesnt mix terribly well.
AlexF |
20th Aug, 2007 at 02:38:19pm
What injector pump is it? Have a look and see if there is anything on it.
20th Aug, 2007 at 02:45:35pm
If its for a heater or you need alot of it, theres a grey area. You maybe able to burn old veggy oil legally. A friend been looking into it. Waste desposal licence. The cost of a licence might be too expensive, I shall keep you posted on his findings. :) On 19th Jan, 2010 wil_h said:
857 Posts Member #: 1778 Post Whore Northants |
20th Aug, 2007 at 02:59:55pm
As AlexF said, you need to make sure it has a decent fuel pump.
Edited by sturgeo on 20th Aug, 2007. |
20th Aug, 2007 at 03:02:51pm
the pump says nothing on it. it's and old perkins engine I think.
20th Aug, 2007 at 03:04:39pm
People seem to get round running 100% veggy. Alot of it is where they are running pre-heaters to thin the oil. Ok on bosch pumps apparently. Other than that...go 50/50 to be safe. On 19th Jan, 2010 wil_h said:
20th Aug, 2007 at 03:23:52pm
Jimster, i'll try and find somemore out about the 306.
20th Aug, 2007 at 03:24:09pm
It can be done, but works better if you can pre-heat it as it viscosity goes down and is easier to pump. It doesn't seem to work well on a cold engine probably for the same reason.
20th Aug, 2007 at 03:29:07pm
A mate of mine was down at Avon with his LDV van. He runs a 50/50 mix with no problems so far |
20th Aug, 2007 at 03:29:39pm
cheers for the info guys On 15th May, 2009 TurboDave said:
20th Aug, 2007 at 03:34:18pm
A few years ago I read that when running a diesel car on heating oil it was best to stick some two stroke oil in as well to lubricate the injector pump. If it is true, this might be a good idea when running on veggie oil. |
20th Aug, 2007 at 04:18:27pm
a friend of a friend had a van and only drove around his private property and he ran a bit of red deisel mixed with heating oil and it had a strange smell when running
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
20th Aug, 2007 at 09:38:42pm
There is a pump that can be used that works on veg oil. It was on discovery a while ago i think. And I think it was a bosch pump as milamber says. Back once again like a renegade master |
20th Aug, 2007 at 11:12:26pm
a freind of mine has a citreon ax and a mitsibushi peoplecarrier type thing and runs them both of vegi. pretty sure its pure vegi. i think that because majority of diesel cars (if not all) have some sort of preheat mechanisms vegi works fine as its viscosity returns before it is injected/burnt.
21st Aug, 2007 at 12:15:45am
http://www.bio-power.co.uk/tryit.htm
21st Aug, 2007 at 01:16:55am
jim RUN A 50/50 MIX
Edited by BENROSS on 21st Aug, 2007.
21st Aug, 2007 at 09:38:36am
It does smell......like cooking batter! Noticed it on the M25 a couple of times. On 19th Jan, 2010 wil_h said:
21st Aug, 2007 at 10:15:55am
I regularly run my sierra td on veg oil, I tend to run veg for a few weeks then go back to diesel, I always find the car starts to feel sluggish after a while on veg oil - I have read the glycirin in the veg oil cokes up in the injectors. Possibly could explain slugishness after a few weeks?
21st Aug, 2007 at 03:23:17pm
The glycerin can be easily nuturalised with an aditive... I'll try and remember which one.
AlexF |
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
21st Aug, 2007 at 03:51:37pm
Jim old chap, speaking from experience with my multi-fuel buggering about, I suggest the cheapest way to do it is to run K-85. Ie Kerosene 85% FRESH veg oil 15% (provides lubrication to your injector pump). Works fine. Used oil has to be transesterified which is messy and time consuming, new oil is a tad pricey (even considering red diesel) Kerosene/Veg oil or 70% Kerosene 23% red diesel, 7% lubricating oil will do it.
Bugger off, I'm getting there. |
21st Aug, 2007 at 04:01:12pm
apperenly make sure its rapessed oil as the engines run better than blended sunflower oil.
21st Aug, 2007 at 10:55:33pm
alex around 5 to 10 years ago diesel oil the viscosity used to be very heavy and oily
21st Aug, 2007 at 11:19:02pm
Fight the power benross. LOL
15 Posts Member #: 1245 Member |
22nd Aug, 2007 at 09:59:49am
Some of the boys over here are running used auto trans fluid in there Ford trucks with no problems....I don't see why it would'nt work in any other diesel....Of corse we work at the dealership and have a ton of it here and it's fricking FREE.....
