| Home > Help Needed / General Tech Chat > Fuel Regulator | |||||||
![]() 111 Posts Member #: 265 Advanced Member Southampton |
13th Jun, 2004 at 08:08:54pm
263 Posts Member #: 115 Senior Member Austria, near Vienna |
13th Jun, 2004 at 08:41:35pm
When your fuel return line is too restrictive you can't adjust the pressure as low as you need it. What ID does your feed and return line have? Bimmer Twinky headed and turboed A-Series:
13th Jun, 2004 at 09:54:05pm
yep, think you'll find that there is too much restriction in the return as Dave found out for our benefit!
102 Posts Member #: 155 Advanced Member |
14th Jun, 2004 at 08:42:32am
what diameter fuel pipe would you suggest to use for the reurn ? |
14th Jun, 2004 at 09:10:27am
14th Jun, 2004 at 09:37:46am
Should be ok with a restriction but if you want to increase the return then that would work aswell.
19 Posts Member #: 301 Member |
14th Jun, 2004 at 09:52:44pm
on my min i put in 8 mm from the pump to the reg and 10 mm from the reg back to the tank like it is on the metro all worked fine got it down to 3 psi |
14th Jun, 2004 at 10:04:07pm
I changed to feed 6mm ID and return to 8mmID and can adjust down to 1,5psi now.
15th Jun, 2004 at 10:14:38am
cheers all
18th Jun, 2004 at 08:54:10am
