Home > General Chat > York today......
Took The DON to the RWYB at York today to give it a run out, managed a 12.79 run in the same configuration at MITP, except with the soft cut rev limiter raised up, it seems my theory that the soft cut limiter was holding it back was true.
Also bumped into Iain of Turbominis who happened to be there with a mate of his, he was kicking himself for not bringing his mini along!
Also tried the gas later on in the day, some horrendous starts and missed gears simply through me trying too hard, but a 115mph terminal on one of the runs tells its own story.
However the day was cut short, as some of you know we had problems at MITP with it blowing a core plug out, this was put down to the sealed cooling system getting overpressurised after doing three runs one after the other. However after running it today, the cooling system was pressurised a ridiculous amount after every run, and required lots of bleeding etc, it seems we have a head gasket problem, so the day was cut short. A shame, as we would have easily won the class we were entered in, the nearest rival was doing 13.3 runs.
Some videos will be up later when I've got them off the camera.
Edited by Tom Fenton on 26th Aug, 2007.
dan
Member #: 93
good proving work Tom, nice to see a sub 13 run at another venue too...
Tom ,i thought the first run with gas had a terminal of 117mph,
carl
Could be right, I'll check timing slips.
Fook!
Run 1
Car as MITP, with soft cut rev limiter raised
2.301 60ft
8.477 1/8
91.48 1/8
12.796 1/4
112.45 1/4
Run 2
Missed 2nd gear
2.232 60ft
8.575 1/8
85.60 1/8
13.057 1/4
110.33 1/4
Run 3
Gas! Hooked 4th early, only used gas in 4th
2.264 60ft
8.673 1/8
87.60 1/8
12.919 1/4
117.43 1/4 (!!!!!!!!!)
Run 4
2.238 60ft
8.677 1/8
84.11 1/8
13.039 1/4
115.33 1/4
Run 5
2.190 60ft
8.950 1/8
86.91 1/8
13.267 1/4
114.75 1/4
Run 6
2.382 60ft
8.768 1/8
90.31 1/8
13.070 1/4
114.16 1/4
well done guys your getting on well now*happy*
On 26th of Aug, 2007 at 07:08pm Tom Fenton said:
Run 1
2.301 60ft
8.477 1/8
91.48 1/8
12.796 1/4
112.45 1/4
Run 2
Missed 2nd gear
2.232 60ft
8.575 1/8
85.60 1/8
13.057 1/4
110.33 1/4
Run 3
2.264 60ft
8.673 1/8
87.60 1/8
12.919 1/4
Right Tom, from the notes we made after each run,
run 1 ,all ok,
run2, bogged off line , missed 3rd,
run3 bogged off line , gas in top only,
we did 6 runs in total , but things were just geting worse with the HG, all low 13s but not nearly realising the full potential of the setup.
carl
Edited by fastcarl on 26th Aug, 2007.
Low 13's you mean Carl! Low 12's I wish!!!!
Slowest time of the day was 13.267 @ 114.75mph, none too shabby.
Looking through Carl, the 60ft times are fairly consistant around the 2.2/2.3 mark.
Although the run that really takes the biscuit has to be the first of the day, really is a storming run, the best to date, and all without the gas.
i think the HG just got worse and worse,,
ps, 12s, i dont know what you meen,lol
Sealed cooling system?
is that solidly sealed or just a very high pressure cap?
how did you measure the pressure? do you have a gauge fitted full time or somthing like a scrader valve fitted?
Mirage
Member #: 119
Tom,
Just an idea you have probably already tried. Have you got the engine and cooling system hot before you cap it, are you running a cap?
Engine i've been doing a lot on lately has a sealed system with no regular expoansion bottle. Uses a small spring loaded piston in cylinder type of volume compensation (bit like an oil accumalator). To set it you heat the engine etc to running temp ( i heat to approx 90). There is a dry break connector on the system that goes to what is basically a water filled syringe. the syringe has a screw thread on the plunger and is set approx midway as you heat up the engine. When its all HOT you bleed rads etc, take of the top up tank. Then set the pressure you want by adjusting the syringe, when its set pop of the dry break and your ready. We run this upto 3 bar as it runs pretty hot.
You even running the radiator ?
Edited by Mirage on 26th Aug, 2007.
All the problems we have had are most probably due to the head gasket, which we finally found today, with the head gasket healthy the car ran at Avon Park with no problems at all, so I'm confident with the gasket sorted the rest of the cooling system should be Ok.
Mirage
Member #: 119
So are you running with the radiator ?
ditto, [ my new word of the day] lol
tom carl , sucking eggs as tom says but , have you enough retard for the gas when it comes in ?
very quick little mini. good work lads.
minipete
Member #: 1890
Driffield East Yorks
Bollocks missed it,i only live 30mins away from York raceway!
East Yorkshire Mini Owners Club.
www.miniowners.freeserve.co.uk
Carl
Member #: 95
liverpool-on-sea
holy shit, good work boys.
Gavin Wakely
Member #: 793
Nice 1 chap's
good going, itll be interesting to see how much the n2o improves things
when are you going to get some decent tyres on it too? those 008's cant be helping
nice one guys! was this on road tyres or slicks??
Did you find more grip at york than pod?
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
scary car lads, its got even more potential which scares me even more.
the 13's jim, flans old metro tyres, which Tom ans myself have considdered to be all but worn out,
i took some slicks from the twinnie but never got to put them on,
carl
