Home > General Chat > What clutch are you running?
Just trying to get a idea of how many nanas and curley wurleys different setups can take?
E.g verto/pre-verto, what colour pressure plate, machined lugs or not on back plate, and how many nanas and curleys you run with that setup?
EDIT: I know a fair few people on here have well over 200 nanas just trying to get and idea if double grey would have to be used?
Matt
Edited by matty on 28th Aug, 2007.
andeh
Member #: 97
Near Daventry, midlands
iirc, and this is going back a while, dave got stuck at around 170-180bhp on a grey clutch - though i maybe wrong!
im on a grey with a race rally back plate
im not sure about my lugs though
Ah thats good to know! Sounds like your running the same setup as me!
Not sure whether to bother machining the lugs in that case?
T3Tone
Member #: 252
Sunny suffolk
I had 1mm macined off lugs to account for using an extra drive strap at each point. No problems using a grey with ap plate.
-MINI CLUBMAN 1380 TURBO-
if you dont get the diaghragm spring flat, you are wasting clamping preasure.
Thats what TD was on about when machining lugs.
Assemble your clutch, look at the spring and if its not flat you need to machine the lugs on the backplate by the amount required to get the spring flat.
Nick
Member #: 154
Midlands
i'm running a grey and a minispares £16 turbo (good for 7k rpm apparently?!?) clutch plate, with the backplate lugs machined down to 23.5mm as per TD's guide. last RR said 163 nana's and 171 curlys @ 15ish psi.
i'm running a paddle on a grey and it seems to be ok so far.
mini23
Member #: 1296
Milford Haven Pembrokeshire
i'm on a paddle with orange and its been ok
Double grey & rally/race plate. My grey diaphragm couldn't handle 16psi so had to change.
I had a grey with an organic plate and it was on the limit with 140 bananas and 135 curlywurlies.
Changed to a MS padle (ther realy heave one) and had no problems, nice progressive plate too.
Im running the organic plate, but im sure that is also refered to as the 'race/rally' plate in minispares. Are these the same plates that everyone is talking about?
Yes
verto rts
150 bhp
all ok .
oh and turbo plate stock bl .
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=10207
theres the link matty .
Yeah I know yours is a one off robert, will be interesting to see how it goes with the boost wound up?
Looks to be built solidly enough, you'll have to keep us posted how you get on. After are conversation the other day sounds like it could be the ultimate test..lol *wink*
I'm using a double grey with AP paddle plate.
Orange, 140bhp
*evil* *wink*
