Home > Help Needed / General Tech Chat > 1275/MPI cyl head differences?
welshdan
Member #: 1111
s wales
was just wondering...are there any significant changes between mpi and normal 1275 heads? are they interchangable? thanks
Edited by Tom Fenton on 29th Aug, 2007.
there are some differences as the alternator fixes to the head on the mpi, and i "think" the temp sensor is different too.
The water temp sender hole and the water heater take off are not drilled, extra fixing holes for the alternator mount, no water by pass, and manifold locating lugs on the inlet ports., that just about covers it.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
As sprocket said.
Easy enough to fit MPi head to older engine but a bit more effort to fit older head to MPi (alternator mount fabrication being the worst bit)
Thats a good point Roger,
For the life of me I can't work out why minisport when the were pissing around with the 7 port casting never added the mpi alternator mount....
it would have opened up a much bigger market....
ie slap it on an mpi with a couple of webber throttle bodies and an emerald box....
On 30th of Aug, 2007 at 01:14pm mini13 said:
For the life of me I can't work out why minisport when the were pissing around with the 7 port casting never added the mpi alternator mount......
Possibly because one of the inlets is there....8)
oh yeah....
duuur!! theres no way that would fit in the mpi position.*blush*
I thought I heard some where that the water ways were ment to be superior, I pretty sure that Nigel Brown is running one on his car for this reason.
Roger, can you have a look and confirm?
As an aside has anyone seen or spoken to Nigel? as it's been years since his last post.
Edited by Rob H on 1st Sep, 2007.
Not actualy having an MPi head to look at i cannot comment on that, however, the water jacket of the MPi block is of a smoother and overall better finish than any of the other blocks i have seen, possibly better casting methods used with a re designed core for the redesigned block?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I'll have a look and report back, I've got several MPi and turbo heads I can compare.
Alex
AlexF
