Home > Help Needed / General Tech Chat > Intercooler piping
PaulM
Member #: 206
Could anyone reccomend aplace for buying ali or stainless i/c piping 50mm i/d. I guess its cheaper, then making it all in hose ??
Paul M
9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked
b12
Member #: 247
Kent/Surrey Borders
I was going to just use 2" exhaust !!
TurboLessTosser
Im thinking of using 2" stainless exhaust stuff as well, using it for standard bends too.
Carl
Member #: 95
liverpool-on-sea
never thought off stainless steel exhaust stuff we change a few of them at work wahoo ill go and search the scrap pile tommorrow *tongue*
You might find the exhaust piping is very thick walled, this may cause a slight loss in flow if you use silicone bends to join it ??
Phil. *smiley*
b12
Member #: 247
Kent/Surrey Borders
I rekon on 2" exhaust .. and 54 mm silicon ?
What do you think ?
TurboLessTosser
b12
Member #: 247
Kent/Surrey Borders
i think i just made a pratt post
TurboLessTosser
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Users viewing this thread: b12, feebleuk
So work it out already!
I dont have a servo, so theres tonnes of space. got everything in now except intercooler and intercooler piping. Cant afford the piping yet!
Im hoping that the exhaust pipe is 2" OD but not sure, should be getting some this week. Im using silicon to connect them but chamfering the inside edge of the pipe so there isnt as much of a step, just whack it in the lathe give it a nice shallow chamfer.
nobbie
Member #: 162
i used 2" exhaust pipe and it works a treat
fireman-sam
Member #: 301
i used bits of a volvo exhaust as they have very good bends that was about 2"
